how to plug up TPMS hole to use TPMS rim on non-TPMS car?
is it possible to safely plug up the TPMS hole on TPMS rims that has had the sensor taken out
so i can use the rim on my 2001 GS300 which doesnt have TPMS?
thanks
thanks
does anyone know if you can use universal valve stems or are there specific standard valve stems that you use with the OEM GS350 wheels? I am also trying to salvage my new tires/wheels taken off my GS and place them on my camry.
thanks for the help!
Maintenance Moderator
all car valve stems are the same diameter - no differences unless you get into the older stuff or truck stuff, and a lot of it is the same too...
so long as the widths and offsets aren't crazy, then your wheels/tires should work on the Camry - same bolt pattern and hub bore
thx mitsuguy. do you know where I can pick up valve stems? (at any autozone or discount tire?) and can it be installed easily or should i have the tire guys do it?
tfeni52355
10-07-08 07:13 PM
