Will these steel wheels work?
I have been searching on CL and on my.is and been getting too much inconsistency whether or not steel wheels will fit on an IS300. Most of these answers are out of date as well so I would like to ask anyone who might know if this wheel fitment will work with my winter tires.
Tire size- 205-55-16
Steel wheel
Bolt pattern-5-114
Offset- +38mm
Rim- 16x6
The steel wheels were off a 2009 Camry and someone is selling these for cheap. I rather just buy these instead of spending $$ on 16" alloy wheels. First, I want to make sure these will work with our front brake calipers. My Sportx will also be lowered a lil over an inch, but I don't think that will be an issue. Also trying not to do any shaving or adding spacers.....Let me know your thoughts!
Steel wheel
Bolt pattern-5-114
Offset- +38mm
Rim- 16x6
Okay...so based on the wheel fitment calculation:
6*25.4/2-38=38.2
front fenders equal 65. 65-38.2= 26.8 mm of clearance
rear fenders equal 68. 68-38.2= 29.8 mm of clearance
so these wheels will fit with 205/55/16
But the real questions is....when mounted, will it hit the calipers? Based on these calculations how would I know if I need spacers to push them out a little bit (I hope this wont be true).
6*25.4/2-38=38.2
