Is this cracking a cause of concern?
O.C. Lucky Strike Fanatic
EDIT: title should be "Is this cracking a cause for concern?"
Hey guys,
This picture is from my 3 series that is parked outside all the time. I put tire dressing on it when I wash and detail the car. I've checked the tirerack.com site for info and it appears that cracking occurs naturally for cars parked outside.
In your opinion, is this cracking a concern or am I ok with driving it the way it is?
Thanks alot!
Hey guys,
Thanks alot!
Hey guys,
Thanks alot!
Hey guys,
Thanks alot!
do you routinely apply tire dressing to the tread or just the sidewalls?
The picture looks like "dry rot" which is not good. Dry rot is usually caused by prolonged direct exposure to UV rays. This is usually seem on the sidewalls. It would be hard to get constant exposure to that specific location on the tread. Is this happening on the entire tread surface and on all four tires? Or is it localized to that area in the picture? If local, I would wonder if you ran through some kind of caustic chemical or something.
steviej
steviej
Thanks for everyones input, please keep them coming.
I will inspect the other 3 tires tomorrow. As for the tire dressing, I only apply it on the outer sidewall.
Could be one of these few things..
1-A lot of direct sun exposure.
2-Age of tires/driving habits ( hard cornering, etc)
3-Camber/suspension/Alignment issues.
I highly doubt its any tire dressing you use. But 25k/2 yrs does take a toll on tires.
I called Dunlop today and they sent me to Just tires for inspection.
The guy at Just tires informed me that I have about 10k miles left in these and he insisted that they are ok in which the California weather causes this to a lot of tires. He mentioned that he sees alot of this and reassured me that it was normal. Any cracks on the sidewall would be a big concern as the wall is the softest spot on a tire.
After inspection, he got in contact with Dunlop and they are offering me $22.18 credit per tire.
