help with valve stem o ring...
Ok so my tires are dismounted and i notice that my valve stem O rings are kinda dried up.. where can i get new ones?
Apart.
Together
These are my Kenstyle rims.. and i checked on their site and did the yen to dollar conversion and it came up to be $15 each or so for a valvestem replacement.. =/
so yea can i get those anywhere?
Apart.
Together
Maintenance Moderator
they *look* like standard metal valve stem grommets... You should be able to go to any Firestone or Discount/Americas Tire and compare. Both places should have them on hand to compare to... cost - $2-$5 each, depending on who you run into... I used to give them away, as they only cost the store somewhere around .25 each... Actually, I don't recall how much the metal stems are... I know the rubber valves were like .10 cents each... I still just gave them away as a nice gesture...
