Can I put staggered wheels on my 06GS300 AWD?
Old 05-24-07, 07:36 PM
StealthAWD
StealthAWD's Avatar
Default Can I put staggered wheels on my 06GS300 AWD?
I thought that staggered was bad for AWD cars? Can someone please clarify this if you know. Thanks!
Old 05-25-07, 09:03 AM
trancuongv
trancuongv's Avatar
contact D2autosports in the vendors section and he can hook you up.
Old 05-25-07, 09:19 AM
Kohinoor
Kohinoor's Avatar
stick with the same width, but use staggered offsets
Old 05-25-07, 01:24 PM
bb430
bb430's Avatar
I had a 96' Porsche Carerra 4, AWD 18x8 front 18x10 rear OEM. I think as long as your tires diameters are with in +-3% you should be OK.
Old 05-25-07, 01:39 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Problem is, Porsches are engineered with the difference...
GS's come with the same size all around...
rolling diameter MUST be with 6/32"
that, or anything more will tear out the center diff... it is not designed to be run with different diameters front and rear...
also, stability control is picky about stuff like that as well...
Old 05-27-07, 02:21 AM
CK6Speed
Super Moderator
CK6Speed's Avatar
I believe CL member Cathifer used staggard rims on her IS250 AWD. Many advised against it, but she had no mechanical or electrical problems to date. I think its been about a year by now. D2autosports I believe were the ones that set the car up.
Old 05-28-07, 09:36 AM
JspecSC3
JspecSC3's Avatar
Just wait for it. It will happen. Its just like when people blow a tire on an all wheel drive vehicle and decide to only replace one. The rule with all wheel drives is that if one tire blows out, the rest must be replaced also if they arent with in the same tread depth range. I'd just keep the same width and get a staggered offset like mr HoeBag and suggested.
Old 05-28-07, 12:01 PM
mitsuguy
mitsuguy's Avatar
yup...
there is some room for differences, but ultimately it will come to how long it will last...
Old 05-29-07, 07:43 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
This topic has been discussed ad nauseam many times over so I'll just save my fingers.
Bottom line, if you want to stagger we have done it on various cars for a very long time. If you dont we have also done same width, staggered lips for about as long. You can choose what route your most comfortable with.
The choice is yours, the limiting factor can be 1pc wheels. Alot of these setups are a bit easier with custom wheels. (not that 1pc is impossible, ie, Cathafers car)
Good luck and happy hunting.
Old 05-29-07, 07:49 PM
JspecSC3
JspecSC3's Avatar
Yeah but is it bad for AWD cars in the long run? I think that was the real question.
Chekmi21
10-11-08 05:34 PM
StealthAWD
05-24-07 08:11 PM
Kevin725
05-03-07 01:02 PM
mctuners
04-08-07 05:27 PM
Quick Reply: Can I put staggered wheels on my 06GS300 AWD?
