Brutal vibration above 50mph w/new 18x9 MB EXE IIs....
Old 05-13-07, 08:13 PM
diamondmit
diamondmit's Avatar
Default Brutal vibration above 50mph w/new 18x9 MB EXE IIs....
....I just put these on yesterday and took my family to see my mother (about 70 miles). The wheels are gorgeous (pictures soon) but the vibration was awful. I'm running 235/40/18s on the front and 275/35/18s on the rear with Goodyear F1 GS D3's.
I'll have the balance checked on Monday, but before I do, is there anything else to look at? I have nice metal centering rings in place and the lugs are all torqued at 72 ft-lbs. I'm really surprised at this - got them mail order from Direct Tire...should have used Tirerack.
thanks
dd
Old 05-13-07, 08:19 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
need to be balanced.
Old 05-15-07, 09:52 PM
JspecSC3
JspecSC3's Avatar
I would also double check the balancing. I see you have the hub rings. Im assuming you are using the correct type of lug nut also right?
Old 05-16-07, 07:41 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Direct is usually pretty good... you might have a tire issue though... one might have a little hop to it that is making it through to the steering wheel... Something that won't necessarily show up on the balancer...
Is it shaking in the wheel or from the rear of the car (seats)?
pauly1976
03-01-16 06:45 PM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
18
12-11-09 05:24 PM
lexboi250
05-19-08 01:48 PM
I8ABMR
01-08-08 09:57 PM
Quick Reply: Brutal vibration above 50mph w/new 18x9 MB EXE IIs....
