What's the widest tire that will fit on OEM front wheels without rubbing?
Old 04-13-07, 10:03 AM
Gernby
Gernby's Avatar
Default What's the widest tire that will fit on OEM front wheels without rubbing?
I'm buying some track tires for an upcoming HPDE, and I'm curious what the widest tire anyone has been able to put on their front stock wheels. I'm currently considering a 245/40-18, but I'm skeptical that it will fit.
Old 04-13-07, 10:36 AM
twkid84
twkid84's Avatar
somebody told me 235 front and 265 rear
it would be great if someone can confirm this because i am changing mine too
Old 04-13-07, 10:57 AM
ben_r_
ben_r_'s Avatar
wow, only 10mm more...?
Old 04-13-07, 11:55 AM
Gernby
Gernby's Avatar
I've seen quite a few people running 235s with bigger wheels and more agressive offsets. I don't know if the offsets actually need to be smaller to keep the wheel / tire from rubbing the suspension, or not. I would hope that there would be just a bit more room to allow the 245s...
Old 04-13-07, 12:00 PM
Rasengan
Rasengan's Avatar
I'm considering purchasing PIAA Super Rozzas for my IS350 Sport and was wondering which offset i should get for the fronts and rears...this is what they offer:
5x114.3 18x8 42 offset
5x114.3 18x8 50 offset
5x114.3 18x8.5 30 offset
I prefer getting 18's because I cannot find all seasons that will fit 19's and I need to get all seasons.
Old 04-13-07, 12:01 PM
t0e
t0e's Avatar
If you get the right offset / width you can run 245's
Old 04-13-07, 12:06 PM
Gernby
Gernby's Avatar
What color IS350 should I buy?
Old 04-13-07, 01:01 PM
Gernby
Gernby's Avatar
I just had one of my 245/35-18s mounted up on an OEM front wheel. I'm surprised at how well the tire fits the 8" wide wheel. I'll mount it up on the car in a little bit to see if it rubs...
javyLSU
2IS OG
javyLSU's Avatar
Go easy on him, Greg - he's a noob. Rasengan, you might want to post your question in a more appropriate thread, or start a new one...
Keep us posted on how that tire fits, this is something I'd like to try as well!
Javier
Old 04-13-07, 01:17 PM
SonnyIs350
SonnyIs350's Avatar
Gernby there is only 1 color you should buy and lexus calls it Obsidian!!!
Old 04-13-07, 01:23 PM
Rasengan
Rasengan's Avatar
yea you're right, i didn't know there was a separate tire and wheels forum here but i guess there is...this thread probably should have been made in there as well
Old 04-13-07, 02:51 PM
kilo6_one
kilo6_one's Avatar
I ran a 245/40 18 front and 275/35 rear with 38mm offset, a little rubbing on inner fender but that is an easy fix since its only the plastic liner.
Old 04-13-07, 02:58 PM
Gernby
Gernby's Avatar
Actually, I didn't even consider the tire and wheel forum, since I wouldn't expect many people to see it there. I just thought it was funny that you asked such an unrelated question. Good luck finding the answer though!
Old 04-13-07, 03:00 PM
Gernby
Gernby's Avatar
That's great! Where did it rub? Did it rub because the offset was too high, or too low (ie. which side of the tire rubbed in what place on the fender)?
jerzyjr
02-21-18 01:47 PM
ADVIS250
06-26-09 11:28 AM
dle
02-25-07 08:20 PM
PhilipMSPT
11-26-05 08:08 AM
Escobar
21
06-13-05 06:22 PM
Quick Reply: What's the widest tire that will fit on OEM front wheels without rubbing?
