GS300 Sport Sedan Rims
Old 03-25-07, 07:48 PM
leksusGS15
leksusGS15's Avatar
Default GS300 Sport Sedan Rims
I want to change the look of my GS300 rims... These darker rims that come on GS300 Sport Sedan look more aggressive and look perfect on silver car... HOw can i make mine darker?
Old 03-25-07, 07:51 PM
leksusGS15
leksusGS15's Avatar
Default GS300 Sport sedan
Any suggestions on how i can do it?
Old 03-27-07, 05:24 PM
kadburry
kadburry's Avatar
paint them
Old 03-28-07, 01:27 AM
sleeper408
sleeper408's Avatar
If you have skills in painting and prep, you can do it yourself, or have a shop paint them for you. My friend painted his wheels and took many steps with great patience and they came out looking OEM quality. Lastly, you can just sell your wheels and find someone selling some SD wheels?
Old 03-29-07, 03:33 PM
leksusGS15
leksusGS15's Avatar
I can paint them, but do i have to sand it down to the surface or just put primer on them, 2 or 3 coats of paint and then clear coat.... I have painted many times, but finding the perfect paint and paint code @ Sherwin Williams will be hard...
Old 03-29-07, 06:47 PM
kadburry
kadburry's Avatar
yes you should sand them down before painting
Old 03-29-07, 06:58 PM
e-man
e-man's Avatar
Here you go:
https://www.clublexus.com/forums/sho...duplicolor+oem
Old 03-29-07, 09:57 PM
LXMN
LXMN's Avatar
Default Light sanding is all that is required
Just break the surface of the paint with some red scotchbrite pad or 1000 grit sandpaper. If you need to get rid of any curb rash, try a coarser grit. It is not necessary to sand down to bare metal.
If you already know how to paint, read no further.
Light coats are recommended and I advise painting the lug holes first and the sides of the spokes second and the flat wheel face last with each coat. In that exact order, as to avoid runs with the best possible coverage. Always paint the most difficult parts first and the easiest last.
Good luck with the project.
lexisaurus
04-28-17 08:55 AM
pwnmanlolz
ES - 6th Gen (2013-2018)
09-30-15 09:05 AM
YeA 2jZ
SC- 1st Gen (1992-2000)
27
11-12-10 09:00 AM
lifeisgood
12-14-09 10:13 PM
Daihuy
08-01-07 10:39 AM
Quick Reply: GS300 Sport Sedan Rims
