will these offsets work for 2GS?
The front wheels will be very "inset." I see that the common offsets for 8.5" and 9.5" are 35mm all around. So with a 8" wide front wheel, you wheels will be inset by .5" and also the offset would be 8mm more conservative.
I hope V8 Aristo doesn't mind me using his pic.
https://www.clublexus.com/gallery/da...904gs111_2.jpg
You can see that the rear is 9.5" wide with 35mm offset which is right about as far as you want the wheel to stick out w/o fender mods. He was running 8.5" 35mm in the front and it looks to be about even with the rear. You can see why if you run a 8" wide wheel with a 43mm offset, it wouldn't match up nicely visually. The wheels will fit and work without problems but like Neo said, "It wouldn't be balanced."
The One
Here is a good read for some specs:
http://www.lgwnorcal.com/articles/wheelfitment.html
