'02-'05 SC430 Wheels on a '97 LS400???
Old 10-18-06, 11:11 AM
LIVN XL
LIVN XL's Avatar
Default '02-'05 SC430 Wheels on a '97 LS400???
Will 18x8 SC430 wheels with a 45mm offset fit on a 97 LS400??
Old 10-19-06, 06:51 PM
LIVN XL
LIVN XL's Avatar
anyone?????
Old 10-19-06, 09:37 PM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
Not without spacers for the front.
Old 10-20-06, 08:03 AM
LIVN XL
LIVN XL's Avatar
thanks for the info! I'm having such a hard time finding wheels for my 97 LS...I don't want to use spacers, I just want direct bolt-ons
Old 10-20-06, 08:23 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
why in gods name would you want those wheels?
10 allen bolts to be removed just to balance a wheel, and they are not very attractive in my opinion either...
Old 10-20-06, 11:59 AM
LS400.1
LS400.1's Avatar
I actually like the look of these wheels on a LS400. Any idea how wide a spacer is needed to fit these on the '95-'00 LS?
Old 10-20-06, 12:13 PM
mitsuguy
mitsuguy's Avatar
5-10 mm should be all thats needs, however, I wouldn't recommend spacers on any vehicle... either way, if you do use spacers, the lugs need to thread down far enough for safety... also, keep in mind, very few spacers will retain the hub centric use, therefore you ~might~ get some shaking from the front...
Old 10-21-06, 12:21 AM
rominl
exclusive matchup
rominl's Avatar
that's it? i thought those calipers, size wise, are similar to the supra tt, meaning bbk fitment? if so, 15mm spacers i say.
Old 10-21-06, 06:52 AM
mitsuguy
mitsuguy's Avatar
oooh, wasn't even thinking that... the 97's were larger calipers, correct, but I didn't think they were Supra big...
15mm spacers won't be safe at all... you won't be able to find bolt on 15mm spacers as 15mm is too narrow to do it right, and 25mm is the narrowest I think I've seen that bolt to the hub, then the wheel bolts to the spacer... either way, I really would never recommend that....
Old 10-21-06, 02:29 PM
rominl
exclusive matchup
rominl's Avatar
i know they have 20mm and 25mm adaptors, do they have 15mm?
Old 10-21-06, 03:03 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
i believe that H&R makes 15mm spacers but not sure if they come with the longer studs you will HAVE to install.
Old 10-21-06, 03:19 PM
mitsuguy
mitsuguy's Avatar
correct...
that sounds like the worst available option though...
would be better off with a bolt on adapter... after the labor of removing and replacing all the studs, it'd be cheaper to buy some nicer aftermarket wheels...
now that I think about it, bolt on adapters are pretty pricey too, so, either way ya go, it's just as cheap to get something nicer...
Losiracer2
08-08-17 09:56 PM
MOlex99
05-16-17 05:38 PM
lp_yang
SC- 1st Gen (1992-2000)
21
03-19-15 08:33 AM
GreenUCF20
01-12-13 04:04 AM
Quick Reply: '02-'05 SC430 Wheels on a '97 LS400???
