Will these sizes and offsets work on a 98 GS400 35mm front and 40mm rear ??
Old 07-20-06, 12:14 AM
05EX
05EX's Avatar
Default Will these sizes and offsets work on a 98 GS400 35mm front and 40mm rear ??
The wheels are 20" X 8.5" and 20" X 10" with a 5 X 114.3 bolt pattern. The offset is 35mm front and 40mm rear. Im looking to do these wheels with the tien s tech springs. Tires im looking at are the Falken FK452 in the sizes of 245/35/20 and 275/30/20 for the rears. are these overly aggresive, will fender mods be needed? Any help would be appreciated.
Old 07-20-06, 12:24 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
i would suggest 235/35/20 for the front if possble. it's pretty aggressive up front, a bit stretch tires would help.
front i think you can roll a bit fender to help clearance, and the rear is pretty safe, probably just need to shave a bit fenders
Old 07-20-06, 12:42 AM
05EX
05EX's Avatar
Thanks for the info. i was looking at this thread https://www.clublexus.com/forums/sho...d.php?t=225074 and was noticing he's the 451 Falken tire and i noticed his seemed to stretch running a 255/35/20 on a 9" rim. Although his offsets are different i thought i may have been able to get away with the 245/35 up front. But i'll take that advice to heart. I read the fitment sticky but just wanted to double check before i place any orders. Now as far as fender mods, can they be rolled, or do they need to be cut or shaved? and do you see where i may run into fitment/rubbing issues up front?
Old 07-20-06, 07:18 AM
BUSTN
BUSTN's Avatar
245's dont match the stretch of a 275.try a 235 and 275 combo better.
Old 07-20-06, 08:42 AM
05EX
05EX's Avatar
ok, thanks for the info 235/35/20 it is.
Old 07-20-06, 06:34 PM
05EX
05EX's Avatar
ok after checking back with the tire maker they only make a 245/30/20 for the front unles i go with a 235/30/20. is it possible to fit it, and go with maybe a 285/30/20 rear. i mean from what i've seen the Falkens seem to not have a blocky shoulder as some of the other makers.
Old 07-20-06, 09:33 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
well in that case i think 245/35/20 is your best choice. as long as they are not meaty that's good i think
Lakersfan
12-01-16 10:03 AM
Vroomin350
01-23-11 12:56 PM
octechgeek
12-03-10 04:22 PM
AznRacer
02-19-10 11:09 AM
tnbigdawg
03-31-07 12:17 AM
Quick Reply: Will these sizes and offsets work on a 98 GS400 35mm front and 40mm rear ??
