Spacers, is it safe?
Old 07-15-06, 11:15 PM
//935GS400
//935GS400's Avatar
Default Spacers, is it safe?
I have 18x8 and im thinking of using 1.5 inch or 1 inch spacers. Do you guys think its safe? thanks!
Old 07-15-06, 11:35 PM
GlobeCLK
GlobeCLK's Avatar
Thye're safe as long as 1) they're made by a reputable company and 2) you install them correctly. Many of us used H&R TRAC+ spacers and they worked great. I believe they go 25mm the widest, which is approximately 1 inch. That should be a safe route to go with.
Old 07-16-06, 06:37 AM
GREED777
GREED777's Avatar
I had this same concern. I had to use spacers on the front to clear the brake caliper. I've had them on for about 9 months now and have had no problems at all. Just make sure as mentioned above that if your not installing them yourself that the install crew does it right. If they don't you may feel wobble, vibration, and could even feel a bit unstable in corners.
Old 07-16-06, 09:50 AM
Pearlpower
Pearlpower's Avatar
Do a search. There are a great many post on this subject here with alot of information . To answer quickly, yes, if done according to what was said above. Much more info under search incl several post explaining them by myself from years back.
Old 07-16-06, 01:05 PM
//935GS400
//935GS400's Avatar
Thanks guys!
Old 07-17-06, 06:17 PM
BRADSGS4
BRADSGS4's Avatar
Default spacers
I run a 15mm and 25mm on my car.
Old 07-17-06, 10:07 PM
martini3
martini3's Avatar
ditto. 15m/front and 25mm/rear on mine. No issues. Just make sure you get the quality brand-name spacers and have them installed by a reputable shop.
Old 07-21-06, 01:48 PM
eskinol
eskinol's Avatar
Some company recommendations for spacers would be helpful Please?
Old 07-21-06, 02:29 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Default ...
H&R
Ramfis
IS F (2008-2014)
10-26-16 08:30 AM
Baby ///M3
10-17-08 05:27 AM
TOMLEXUS
04-18-08 04:47 PM
Dx3
Suspension and Brakes
03-22-05 05:46 PM
SC400TT
12
03-19-05 10:35 PM
Quick Reply: Spacers, is it safe?
