Big Brakes = Spare Tire ??
Old 09-27-05, 02:05 AM
lexusondubs
dubsonlexus
lexusondubs's Avatar
Default Big Brakes = Spare Tire ??
just curious is there any stock lexus wheel that will fit over a front and rear BBK ?? also will it still fit in the stock tire well ?? i know this should be in the wheels section but i wanted to get the most exposure here first thanks
Old 09-27-05, 02:51 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Just add a 20mm wheel spacer and the stock 17" wheel will clear most BBK kits up to a 13.5" rotor.
If you have a rotor larger in diameter than that then the answer is no, a stock wheel will not clear.
Might wanna buy a set and split the set with another BBK owner.
Old 09-27-05, 04:08 AM
lexforlife
lexforlife's Avatar
shawn , right now gs300 rich and a couple of other locals are waiting for me to find a set of 04 350z track edition rims or 04-05 g35 wheels which are the 19in .. these have a 30 offset and high disk design that should clear no problem... if you have a chance and can test fit one please let us know and if you run across a set i am in for 1 right now
Old 09-27-05, 04:16 AM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
Here's the solution I'm using (posted in this thread)
https://www.clublexus.com/forums/sho...d.php?t=138514
It fits in my OEM spare tire wheel well and think my total package was less than $300 - $350 with tire shipped.
Old 09-27-05, 10:49 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Supra TT spare tire... I got this from Ed... It will clear the supra brakes but not sure if any other brands
Tony
Old 09-27-05, 11:29 AM
Neo
The One
Neo's Avatar
If you have a 14+" rotor, then you will need appropriate size rims. For example, 14" rotors need 18" rims. Then you will need to determine caliper clearance. 06 GS430 rims should fit most BBKs. L-Tuned fronts should fit a few like StopTech and Brembo. G35/350Z sports wheels should fit since they have to clear the Brembos.
There are others like what Dave is using.
Old 09-27-05, 11:33 AM
lexusondubs
dubsonlexus
thanks guys iam going to try the 350 wheels and the g35's also i like the 06 gs wheels do i have to use a spacer with any of these ??
Old 09-27-05, 12:17 PM
Neo
The One
Neo's Avatar
I don't think so. What BBK are we talking about here?
Old 09-27-05, 01:31 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
if i have to guess, i think the 06 gs430 wheels would clear bbk, or at least very close
the g35 coupe 18s should clear a lot of bbk too. you don't necessary have to go 19s
Old 09-27-05, 04:06 PM
svt5150
svt5150's Avatar
The 17" GS will fit with a spacer. Otherwise I would probably go with the G35/350Z upgrade wheel.
Old 09-27-05, 06:44 PM
lexusondubs
dubsonlexus
i spoke w/ ken today he said i could get away with the stock 17 in the front and rear cause of the custom rear bbk and the front i could get away with a 3mm spacer which i already have on the car as of now to clear the front calipers so now who has a stock 17" for sale LOL thanks guys
Old 09-27-05, 07:01 PM
LXOGOOD
LXOGOOD's Avatar
Just so everyone understands, we are talking about the Rotora 330mm.
Old 09-27-05, 07:50 PM
lexforlife
lexforlife's Avatar
shawn i thougt you had the 6pot fronts and 4pots rear 355mm rotor
Old 09-27-05, 08:12 PM
lexusondubs
dubsonlexus
naa 4x4 setup
Old 09-27-05, 08:51 PM
Received 2,499 Likes on 1,642 Posts
Viable spare depends on the BBK setup.
I got an L-Tuned 18" (8.5" wide I think) front which JUST fits over the StopTech 14" BBK.
Some mention using a spacer - isn't that a non-trivial thing to install at the side of the road!?
Quick Reply: Big Brakes = Spare Tire ??
