Okay, Need Pics of 20x10's Rear Please...
Old 01-14-05, 04:13 PM
D-MAN63
D-MAN63's Avatar
Default Okay, Need Pics of 20x10's Rear Please...
Preferably with 285/30/20.. I have 275's currently on my l-sportlines but the next set of tires, I want to see if I can do 285 with the same ride height(tucking).. I do have a +48 offset but I want to see how 285 compare to 275's in terms of appearance..
TIA
Old 01-14-05, 08:25 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
rmmgs4 is one person that i remember who had 285 and now 275, you can ask him for pics (but he has 19x10)
imho the difference between 285 and 275 are very little in terms of the height for tucking
it's going to be quite a bit fatter though, but with your offset you should be ok
Old 01-14-05, 08:48 PM
bluelex
bluelex's Avatar
Alwilliams and indio have 285/30/20 on 20x10's i'll find some pics for you...
Old 01-14-05, 08:52 PM
bluelex
bluelex's Avatar
don't know if you can really tell in this shot but i fugured since it has both mine 275/30/20 stone so-3 and Al's 285/30/20 stone so-3 it might help a little
Old 01-14-05, 08:57 PM
bluelex
bluelex's Avatar
heres 2 20x10 on 285/30/20 so-3's
Old 01-14-05, 11:32 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Default ...
20 x 10 on 285/30/20
Old 01-14-05, 11:41 PM
400DGRZ
400DGRZ's Avatar
Seize, you have some beautiful wheels man!
Old 01-15-05, 05:06 AM
D-MAN63
D-MAN63's Avatar
Hey guys, thanks for the info/pics... There is very little difference but it does look like 285's appear to me that they fit better on 10's.. no??
Sieze, how low is your drop? From that angle it looks like you have no finger gaps and looks like you are rubbing.. You have a +48 offset as well?
Old 01-15-05, 05:28 AM
bluelex
bluelex's Avatar
i don't think they fit better , but they do make it look thicker. it depends on tatse. some like the 285 look cuz it looks meatier but it sometimes makes the wheel look smaller and some like the 275 cuz it looks even with the lip of the wheel thus making your wheel's lips look bigger and flush.
with seize he has a 1st gen gs which has much bigger wheel wells so you can't really look at his tires to wheel well as an example.
Old 01-15-05, 02:31 PM
D-MAN63
D-MAN63's Avatar
Ahh thanks Adrian.. I didn't think of it like that.. . Thanks for the info!
btw: when you coming around ny again? we gotta me ya know!?
Old 01-15-05, 04:37 PM
bluelex
bluelex's Avatar
i'm going up end of jan. or 1st week of Feb. not sure yet...
Old 01-16-05, 11:29 AM
blueGS400
blueGS400's Avatar
i agree with blue, the 275 has a better appearance to me, i went the same setup
Old 01-16-05, 10:12 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
but of course, if you want traction than 285 should be the way to go. i have 275 and i think that's enough, though to me, i think 285 looks better on the 10
Old 01-22-05, 05:56 PM
mikal
mikal's Avatar
Will there be the need of any fend mods if using 285/30/20 on the back?
I have another question that i hope you guys can answer for me.
I want to pick up a set of Falken St-115 because they last pretty long compared to the Toyo T1-S
But they only make 275/35/20. Will i have any problems with it on my +42 Offset for my 99 gs?
Old 01-22-05, 08:20 PM
Neo
The One
Neo's Avatar
You should be fine. You may rub if the offset was lower. I have not see the Falkens in question but sometimes tire shape comes into play as different manufacturers build up the tires slightly differently. Other than fender modding, you can go to 265s but that is not optimal to do. I say go with the 275s and see but there are other members here with 20s with +42 offset and they are fine.
I know that D2Autosport has his iForged 20x10 with +42 rear. Mine is +38 and I had to shave so it does not take much to cross into fender mod territory.
Quick Reply: Okay, Need Pics of 20x10's Rear Please...
