Hubcentric Wheel Topic Update: iFORGED wheels are avail hubcentric!
Old 06-20-06, 03:44 AM
  #31
GS300Rich
GS300Rich's Avatar
Go ahead any put your order in the GB chuck
Old 06-23-06, 12:45 PM
  #32
I6turbo
I6turbo's Avatar
Originally Posted by OneTonVIP
The only REAL use of the hubcentric ring is to accomodate for people-and mostly shops- that rush their wheel installs, and don't take the proper torquing procedures of bolting down the lug nuts in a cross pattern, and in steps. When you just tighten the lug nuts one at a time, in a non-cross pattern, you essentially tighten the wheels on unevenly, and the wheels end up going on a little off-center. Hubcentric rings prevent this from happening by centering the wheels before you even tighten the lug nuts... but they are not really necessary. People have been having no problems for decades before the advent of the hubentric rings... and usually, when you're running an expensive aftermarket wheel, you already should be torquing down the wheels correctly anyway. So whether you run with or w/o rings, just make sure you torque your lug nuts in a cross pattern, and in several steps before the final torque down (doing this assures the conical section of the lug nuts do the job of centering the wheel), and you will be safe. Oh yah, and you will also want to torque the wheels in the air. Once you let it sit on the ground and place weight on the wheels, they will shift slightly...
Old 06-23-06, 03:21 PM
  #33
chuckb
chuckb's Avatar
Originally Posted by rominl
man people who can afford wheels like this i can't believe they dont' spend the extra money
that's what I'm thinking. isn't it only an extra $50 or so?
Old 06-23-06, 03:47 PM
  #34
pvo
pvo's Avatar
Derrick mentioned it's $190 per set.
Old 06-23-06, 07:03 PM
  #35
rominl
exclusive matchup
rominl's Avatar
although personally i don't think it makes sense to pay the extra when y ou are already getting custom wheels, but 190 / 4000, which is less than 5% of the price of the wheels, i would just do it
Old 06-23-06, 08:05 PM
  #36
punch10
punch10's Avatar
Yes, it does makes sense do pay the extra 190.00 per set. I initially wanted to go hubcentric, but in the end it really didn't matter so I bypassed it.
Old 06-29-06, 06:50 AM
  #37
tonydt1g3r
tonydt1g3r's Avatar
when you guys mention a little vibration problem what does it feel like? is it a constant vibration that increases with speed or just a small vibration at a certain speed?
Old 06-29-06, 09:41 PM
  #38
rominl
exclusive matchup
rominl's Avatar
could be both, but a lot of times it's the later case, only at certain speed, and from small the moderate vibration
Mnstrmag
02-04-18 10:18 PM
AJLex19
01-13-16 11:53 AM
SNiiP3R
03-07-09 01:09 AM
cmc07e
07-30-07 09:50 PM
Quick Reply: Hubcentric Wheel Topic Update: iFORGED wheels are avail hubcentric!
