Put 5/120 on 5/114.5 bolt pattern?
Old 04-03-04, 12:59 AM
kazama
kazama's Avatar
Default Put 5x120 on 5x114.3 bolt pattern?
Is there a way to fit 5x120 bolt pattern rims on my 95', SC 300? Adaptor? Spacer? Suggestions?
P.S. The rims are Enkei Aegis 18" 8.5, +12
- Beautiful Black - 1995 - SC 300 - 5x114.3 mm bolt pattern -
Old 04-03-04, 03:11 AM
legendary
legendary's Avatar
in reality....no
it is possible IF they are designed as such that there would be room to DRILL them to fit. But if they are a design like the Zauber Gettins, where the bolts are exposed, it would NOT be a good idea, as it would have 10 unevenly spaced holes and would be ugly as hell.
Second thing to consider is the offset. 5 x 120 sounds like BMW, and I am sure that puts it in a 20 offset range (which is too low an offset)
In other words....DON'T do it
Moving to Tire Rack forum
Old 04-05-04, 01:31 AM
rominl
exclusive matchup
rominl's Avatar
can it be done? yes
would i do it? no
should you do it? no
i would never redrill a wheel to make it fit on my car
Old 04-05-04, 01:47 AM
kazama
kazama's Avatar
Default 5x120 to 5x114.3
Drilling the wheels is NOT what I consider as a option. I figured, there must be easier solutions such as bolt adaptor or spacer with bolt pattern converter. Some genious must have come up with this idea and already have such product for sale. However, I've not been able to find one on the net!!!! So, HELP!
vr4gt
SC- 1st Gen (1992-2000)
13
03-25-13 08:36 PM
Goosesedan
07-25-08 12:12 AM
m0t03
03-11-04 10:19 AM
m0t03
03-02-04 11:10 AM
enginyr
11-30-01 11:40 AM
Quick Reply: Put 5/120 on 5/114.5 bolt pattern?
