brakes on sc with 20's
Old 03-04-04, 05:43 PM
twankys
twankys's Avatar
Default brakes on sc with 20's
will i need new brakes when i put my 20's on and what should i get and how much will they run me and where can i find them
thanks
ryan
Old 03-04-04, 05:53 PM
Vegassc400
Vegassc400's Avatar
Stock wheels weigh in around 45 to 48 pounds. 20's will be around 65+ pounds. I'd sure do it.
The Supra TT brake upgrade is the most popular. Do a search on your options.
Old 03-04-04, 06:22 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
twankes, you have a thread relating to your 20's. do not start a new thread everytime you wish to add to your question on 20's, post within your old thread.
also, we have a forum for each specific part such as brakes, suspention, and so forth.
if you wish to search for a thread you have started that you cannot find, click the search button under your post in a thread.
Old 03-04-04, 06:48 PM
Hermosa
Hermosa's Avatar
In a very simplistic view of the problem:
use Mass x Velocity x Radius for angular momentum
the radius 8 inches for the 16 inch rims
the radius 10 inches for the 20 inch rims
Let's just assume the weights will be equal since the 20s will be made out of lighter and more durable materials (hopefully)
that leaves a simple ratio based on the radius since we are assuming the same weight
that comes out to 25% more momentum on the 20" rims
if you add more weight then this will increase as well
This also correlates with at least 20% less stopping power. The brakes on the cars are spongy so I would not recommend the rim upgrade without a brake upgrade unless you buy something real light. Even then the small brakes look funny.
Old 03-04-04, 10:09 PM
rominl
exclusive matchup
rominl's Avatar
i have driven a GS with 20s and stock brakes. let's just say i almost crashed it when first braked. there were just nooo braking power (of course, maybe coz' i am spoiled with my ap racing)
and not all 20s are that heavy. my 20s they are probably around 50lb each together with tires
and for brakes man, that's such a broad question..... so many options and the price range is huge too
Old 03-12-04, 01:28 PM
DXC
DXC's Avatar
Default Brembo???
How come no one mentioned Brembo??? Is that too expensive???
nar8ta
Suspension and Brakes
25
03-11-09 05:50 PM
cmc07e
18
07-11-07 05:50 AM
ScottURnot
09-21-04 02:22 AM
Zer0
08-20-03 09:49 AM
heavy wate
03-12-03 10:07 PM
Quick Reply: brakes on sc with 20's
