psi question
psi question
im running 18x 9. 245 wall. lowered with stiff suspension gs. i like to keep my psi way lower then the side wall suggests? also tire shops always over inflate your tires. what are some of you guys running? 30 psi? do you keep it the same all the way around? or is it better to keep the rear at a higher psi then the front?
on a side note i got my tire patched from the inside (damn screw) i was told this lowers the speed rating by 10 mph??? also i was told they didnt need to rebalance b/c they mark the tire. so does that even have any relevance or is it so minimal its just a technicality? any input would be greatly appreciated. thanx to all.....
