Will this clear the Rotora Big Brake??
Hi Guys..I was wonderin if this will clear the Rotora Big Brake 330MM....17x8 with offset of 38..will it clear or do i need a 5mm spacer..Any input will be very helpful...Thanks Jimmy
I thought you had the Stoptech from Todd? I needed a 3mm spacer to clear mine. Do you have the 2 piece rotors or the 1 piece? I have the 1 piece. I had 20x8.5" with a 43* offset. I should note it doesnt matter about the offset it is the Disk. Is it the OEM 17" or an aftermarket?
Originally posted by Neo
I thought you got the StopTechs too.
Anyway, the best way is to try the template. Unless the wheel is high disc, there are too many factors to consider. The style/shape of the wheel comes into play too and that's a hard thing to predict.
TonY_G
Suspension and Brakes
04-22-07 10:32 AM
