Suspension Springs, shocks, coilovers, sways, braces, etc.
Not sure if RSR Down will be enough
Old 06-07-14, 05:57 AM
CincyBrad
CincyBrad's Avatar
Default Not sure if RSR Down will be enough
Looking to lower the GS, I have a AWD model F-Sport. Nebula Gray. I really like the look of the matte gunmetal VBM8's from Velgen on the car, but I am not sure if the RSR down springs will be enough for the look I am going for. Would like it to turn out like the pic below.
Super downs scare me off due to the camber issues, I don't really want to replace expensive rubber every 7-10k miles
Opinions? My concern is the down springs would still leave too much wheel gap and it would look bad.
Old 06-07-14, 08:49 PM
simonsez
simonsez's Avatar
1. flip tires u can run extra 7-10k miles
2. proper alignment can help camber wear as well
3. camber kit
Old 06-08-14, 07:54 AM
LexFather
Guest
Posts: n/a
Here is my wife's car with RSR-Down Springs...for me it isn't low enough but for her it is perfect. Tires every 7-10k miles sounds very excessive....
Old 06-08-14, 08:55 AM
CincyBrad
CincyBrad's Avatar
Nice, looks good to me! Is it AWD? Mine is, from what I have read, the regular down springs will only get it to the stock RWD height.
Old 06-08-14, 08:57 AM
CincyBrad
CincyBrad's Avatar
3. camber kit
With Super Downs, many are having issues getting the alignment back into spec. There is no camber kit available for the 4GS. That's why I was only looking at the regular down springs. Super Downs will probably create a camber issue that cannot be fixed, and will eat rear tires pretty fast.
Old 06-08-14, 11:51 PM
GSthe4th
GSthe4th's Avatar
Do you plan to run a staggered set up? That seems to be a big cause of the rear tire wear after lowering AWD, if you search through the forum. If you run 20 x 9" on all four corners I would be curious to see the results on wear.
Old 06-22-14, 08:00 PM
LexFather
Guest
Posts: n/a
Talking
My wife's car is RWD.
Old 06-26-14, 07:25 PM
168Motor
Former Sponsor
168Motor's Avatar
Wow, beautiful!!
Old 12-22-14, 06:11 PM
Atomic350F
Atomic350F's Avatar
This car looks great!!
How does it ride compared to stock? I am hoping to keep the smooth ride but lower the stance a bit on my RWD..
sjgIS350
01-05-11 05:14 PM
Minderaser
08-23-07 07:11 AM
Mike
GS - 1st Gen (1993-1997)
10-25-05 11:23 PM
Little_D
Wheels, Tires & Brakes Forum
01-23-05 10:15 AM
Blanco
Suspension and Brakes
08-05-04 09:57 AM
Quick Reply: Not sure if RSR Down will be enough
