Suspension Springs, shocks, coilovers, sways, braces, etc.
Installing RS-R coilovers this saturday, got a quick question.
Old 05-01-14, 03:38 AM
SNiiP3R
SNiiP3R's Avatar
Default Installing RS-R coilovers this saturday, got a quick question.
What did you guys do with adjustable dampening motors? RS-R coils are obviously not compatible with that feature. So, did you remove the motors or unplugged them somehow?
thanks
Old 05-01-14, 06:53 AM
G-SharK
G-SharK's Avatar
You might want to check here, https://www.clublexus.com/forums/suspension-243/
I believe they just left it where it is unplugged.
Old 05-01-14, 08:27 AM
DoriSaru15
DoriSaru15's Avatar
I left it plugged and zipped tie it somewhere you cant see it. Which one did you get? sport or black?
Old 05-01-14, 08:53 AM
SNiiP3R
SNiiP3R's Avatar
Thanks! I'll zip tie mine to something as well then.
I got the sport ones. I wish they would make black series for AWD.
Old 05-01-14, 09:32 AM
GSTONY
GSTONY's Avatar
I remove mines And put it in a box, no need to leave it there and let the motors running for no reason.
Old 05-01-14, 12:54 PM
SNiiP3R
SNiiP3R's Avatar
how difficult was the removing process ?
Old 05-01-14, 02:48 PM
DoriSaru15
DoriSaru15's Avatar
Its easy to remove the unit. The most annoying part will be taking out the panels in the trunk and setting up your suspension. especially the rear.
Old 05-01-14, 05:31 PM
SNiiP3R
SNiiP3R's Avatar
Yeah, that won't be easy but worth the hassle
Old 05-01-14, 07:36 PM
LexFather
Guest
Posts: n/a
SNiiP3R you are doing it yourself?
Old 05-01-14, 10:03 PM
DoriSaru15
DoriSaru15's Avatar
Oh yeah when you install the rear have the coils in the highest and work your self down it will save you from taking the arms apart again.
Old 05-02-14, 03:16 AM
SNiiP3R
SNiiP3R's Avatar
A friend is actually helping with the install
Thanks for tip!
Old 05-05-14, 10:27 AM
SNiiP3R
SNiiP3R's Avatar
What did you guys do with the rear adjuster for the spring? I left mine in the same position as it is shown in the picture below. My ride is very bouncy, I'm trying to find out why.....
Old 05-05-14, 12:23 PM
kydoshin
kydoshin's Avatar
I don't remember setting mine that far down. How's the height?
Have you played around with the adjustable damper settings on the shocks?
Old 05-05-14, 01:09 PM
SNiiP3R
SNiiP3R's Avatar
Its pretty low.....Im at 18 clicks, so in the middle right now.
Old 05-05-14, 01:13 PM
Dukeaudio
Dukeaudio's Avatar
I agree...i'd be looking at shock adjustments as well
Quick Reply: Installing RS-R coilovers this saturday, got a quick question.
