Megan LP Coilovers!!!
Yep, that's what I was referring to...wonder if anyone will create a kit for it or mod the existing system to have that ability. I doubt that it would matter much anyways if that kit existed.
if the coilovers are not significantly lighter than stock shocks, then I'll likely forgo this option.
You can check the parts here.
i guess i just need to put the car on the lift and take a look and see which style shock i have because its showing 2 different shocks
With these coilovers, are you able to get your alignment back to factory specs or will you also run into the negative camber issues like the posting by Chuh with the RS*R Springs?
Understood. I suppose I should have asked the question of how much of a drop can you achieve before you run into the issue of NOT being able to have the alignment back to factory specs and eating up tires? I don't see the trade off on looks vs tire cost until the other vendors come out with a camber kit for the 4GS. If someone could advise on how low they were able to drop their car and still get factory specs on alignment it would help a lot of members on making that decision of coilovers vs springs for Pro's and Con's. Having owned previous M3's and a M6 over the years before making the switch to Lexus, I was not really concerned about the fender wheel gap look until I mounted my 3pc wheels to say it definitely needed to be lowered. 8-) Thanks in advance!
