For those of you with Tein CS and 19s
I have 20s not 19s but my CS are about .5" from the lowest they can be and the rear is tucking and the front is just low enough not to scrape. Since you have 19s I assume you can go even lower. But I wouldnt set it at the lowest setting. My EDFC is set to 5 front and rear. Once the body kit goes on it is going to 0 front and rear. Hope this helps
Is this low enough.....
I think I only have 3 threads left on the front...any lower and I would "thump" anytime I hit a bump. My EDFC settings are 3 up front and 5 in the rear...
thanks guys - as you guys may know I just got my wheels and am going to get the teins installed so when the shop installs it, i just wanted to see how I should set my height and softness so I wouldn't have to go thru it a second time around.
hmmm, I thought the lower the #, the stiffer it got? btw, do I want stiffer in front or rear and what would it do?
Originally posted by Neo
I would think that would not be that bad. 0/0 is softest and 3 is not that far from it.
The One
As for its effects, the obvious one is how the coils react to road conditions thus affecting ride quality. There are also issues in terms of handling but that also depends somewhat on what else you have on the car (bracing, bars, ...). I have my theories but I'll let the real hardcore suspension gurus chime in more on this before I put my foot in my mouth.
The One
Originally posted by FutureGSorIS
It is the exact opposite on the edfc. in the 16 increment 16/16 is the softest and 0/0 is the hardest. Or if you have it on the 32 increment then 32/32 is the softest.
I have my edfc set to 0/0 to get used to it once the WIN kit goes on. I also have only around 5 threads left front and back so I am pretty low. Set the rear softer than the front, if that is how you do it. Depending on how low you go you will want the front to be pretty stiff. I just finished custom mounting my EDFC in the dash and will put up some pics as soon as I get my camera back.
Why do you 2 CS guys have your edfc set for such a harsh setting? Is it still soft at 3/5 5/5?
FutureGSorIS: What TEIN setup do you have?
Originally posted by LXOGOOD
With the CS, there's no such thing as a harsh setting! I think at it's stiffest setting it's a little stiffer than the L-tuned setup... I usually go 0/0 when I'm driving on the Fwy/Hwy at speeds greater than 60mph.
thanks for your help guys, I am gonna tinker with it and see what settings I want it to stay at. your numbers will give me a reference as to where I can start.
