Help with running 3/8 air lines
Old 01-02-17, 12:05 PM
Rtran
Rtran's Avatar
Default Help with running 3/8 air lines
I was wondering if anyone that had experience running 3/8 air lines under car could assist me in which route you used?
The 3/8 air lines were to hard for me to run inside of the car. Help would be greatly appreciated.
Old 02-21-17, 02:50 PM
Gerxiong89
Gerxiong89's Avatar
mines 1/4 but 3/8 lines will fit as well. I ran my through the side skirts.
Rtran (02-23-17)
Old 02-23-17, 02:48 PM
Rtran
Rtran's Avatar
Thanks for posting, I didn't think of this during the of my install and ended running all the air lines inside the car.
It was definitely challenging but I made it work.
Old 02-23-17, 02:59 PM
Gerxiong89
Gerxiong89's Avatar
np. I think im the only one that ran it through the side skirts. It was easier for me.
Old 02-23-17, 11:06 PM
specONE
specONE's Avatar
scary thought running the airlines through sideskirts.
Imagine getting tboned and it compromises the air lines in the process, the car will just drop onto the ground at the same time suddently
I dont know why everyone loves running 3/8 lines.
1/4 so much easier to work with. It bends easier and can be routed through the car.
And there isn't no sudden violent up and down when airing up or out.
Old 02-24-17, 10:03 AM
Gerxiong89
Gerxiong89's Avatar
you would have to be tbone pretty hard and at the right spot to compromise the air lines. Just avoid getting tbone haha.
Old 02-24-17, 10:05 AM
specONE
specONE's Avatar
just messing with you..
its a cool idea but just have to think precaution thats all
Old 01-23-18, 12:45 PM
LexoticJ
LexoticJ's Avatar
I think Im just going to run mine through the car.
Old 01-23-18, 03:50 PM
specONE
specONE's Avatar
I dont recommend trying to run 3/8 airline inside the car. I would go straight outside and route it under car. It is just too thick and does not bend easily if you need a tight bend.
1/4 airline you can run inside and even go through the firewall grommet easily.
LexoticJ (01-24-18)
Old 01-24-18, 08:23 AM
LexoticJ
LexoticJ's Avatar
Im going to look into it and see I will play around with running it outside the car as well as in... I went 3/8 because of the faster fill up and less waiting time.
The only place I think the bend will be an issue is going through the fire wall under the dash possibly. Everything else seems like an easy routing point.
Old 01-24-18, 09:24 AM
specONE
specONE's Avatar
Good luck. Just giving out suggestion.
I've done many Air suspension cars and 3/8 is a pain to run and airing up and down is too violently fast for my taste.
We did one car with 3/8 and in the end swapped out the lines for 1/4 after.
LexoticJ (01-25-18)
Old 01-25-18, 06:00 AM
LexoticJ
LexoticJ's Avatar
Just watched a video on what you meant by violently airing up fast... thank you for that.. I will be definitely switching to the 1/4
Old 02-03-18, 07:20 AM
Wsitywim
Wsitywim's Avatar
With 3/8 its only a "violent" jerk if you don't run silencers. If you put silencers on the solenoids it airs up slower and silent. Food for thought.
Old 09-17-18, 04:57 PM
TOPENDMS
Former Sponsor
TOPENDMS's Avatar
1/4" lines are fast in my opinion, and they are able to run through the firewall grommets. I would highly recommend 1/4".
08sgmis350
02-19-13 09:11 AM
Snguyen408
07-29-11 08:33 PM
sticky4
06-25-11 12:48 PM
Quick Reply: Help with running 3/8 air lines
