Are 2014+ IS350/IS300/IS200T front brakes compatible with my 2014 AWD IS250?
Old 09-14-16, 04:26 PM
DEMONX
DEMONX's Avatar
Default Are 2014+ IS350/IS300/IS200T front brakes compatible with my 2014 AWD IS250?
hello,
i currently purchased EBC brakes for my 2014 IS250 AWD but I'm not too happy on how they look. Are 2014+ AWD 200t/IS300/IS350 calipers, pads, rotors compatible with my 2014 IS250 AWD?
suggestions? Comment below..
thanks
david
Attached Thumbnails Are 2014+ IS350/IS300/IS200T  front brakes compatible with my 2014 AWD IS250?-image.jpeg
Old 09-15-16, 08:00 AM
DEMONX
DEMONX's Avatar
No one has done this??
Old 09-15-16, 09:46 AM
E46CT
E46CT's Avatar
Received 2,079 Likes on 1,570 Posts
Cross-reference the front hub/spindle in a parts diagram. See if they are the same or have similar mounting locations. AWD may need a different hub design to get the axle through. I believe the front shock is different. You'll have to do some homework if nobody has done it. If the IS300 is AWD and has the big brakes, then you should be able to do the swap. Can't imagine them using a different hub.
Old 09-15-16, 04:21 PM
SKUM
SKUM's Avatar
Dunno about the 200t brakes, but you can directly swap over the 350 brake assembly.
You'll need the splash shields (or shave the edges of the original ones to fit the larger rotors)
Calipers
Rotors
Pads/Shims
Slider Pins
I've done this and haven't had any issues. Instead of OEM Rotors and Pads I am running Stoptech Slotted & EBC Reds.
Old 09-15-16, 07:19 PM
DEMONX
DEMONX's Avatar
Calipers
Rotors
Pads/Shims
Slider Pins
thanks for the help boss! I found a guy on fb that did it too and yeah it deff works with IS350 front brakes. The 2014+ GS350/GS350 F SPORT (same part number for calipers) is also compatible.
do you know the part number for the EBC pads?
thanks!
Old 09-15-16, 09:10 PM
gpxluke
Former Sponsor
gpxluke's Avatar
If you wanna upgrade your brake, I would suggest go for RC350/GS350 Fsport brakes they are bigger 4 pot calipers and for sure bigger rotors as well.
Old 09-16-16, 05:58 AM
DEMONX
DEMONX's Avatar
what year?
Old 09-16-16, 06:39 AM
DEMONX
DEMONX's Avatar
So going over some parts numbers according to Autozone.
2014+ GS350/GS350 F Sport
2015+ IS350
2015 RC350 F Sport
2016 IS200t (calipers not available on autozone web but rotors are same part number as the others. So I guess they use same front brakes)
have the same calipers, brake pads and rotors..
Old 09-16-16, 10:22 PM
gpxluke
Former Sponsor
gpxluke's Avatar
2015+ IS350
2015 RC350 F Sport
RC350 and GS350 Fsport RWD share the same caliper which is slightly bigger than the IS350 brake, and they use 2 pieces rotor, pls check the pic below
gerardle
Suspension and Brakes
04-16-20 04:52 PM
JaeISF
03-04-18 06:12 PM
jonathanz
08-29-14 04:12 PM
GSE25
30
05-03-13 08:12 AM
Toyota_F1
03-17-11 05:53 PM
Quick Reply: Are 2014+ IS350/IS300/IS200T front brakes compatible with my 2014 AWD IS250?
