2015 IS250 F Sport Brakes already need to be replaced??
Everything I've read indicates the OEM F sport brake pads are 17.2mm. These are the specs that show up when I searched the part number. Can anyone provide a link that proves otherwise? I'd really like to know the specs so I can estimate actual replacement.
Anyway 8mm out of 17mm at 45k doesn't seem too far out there. I'm not getting anything close to that, but my miles are mostly city.
Well that's an utter lie.
Factory F sport brake pads have 9mm brand new. Census on this forum is that factory pads lasts about 15-25k miles. Someone changed your pads without you knowing.
I owned about 10 different cars past 15 years and none of them lasted more than 45k miles regardless of what type of vehicle it is.
So you drive 40k miles a year ? how did you know the pad is worn ? brake pad wear out slow or fast its depend on the driver if he/she grind it or use engine brake or manual trans brake, don't blame the auto maker it's your driving and braking habit, i drove 5 speed standard Triptronic paddle shift and regular Automatic trans like old Camry, we replace the trans on 1997 Honda Prelude in 2 years because we used Manual shift to brake, we change Clutch more often on 2000 Toyota Celica and Brake pad on Toyota Camry, owned a 1992 Supra almost 3 years but i don't wanna count it because i didn't have the car that long.
10 different cars and none of them last 45k miles ??? that's an utter lie. no matter what OEM Brake PAD will last longer than any performance or aftermarket pad and they are good. i aware that performance pads wear out faster than normal one but again depend on the drivers too.
Well he did say he was at 8mm. My 2014 IS250 Fsport is at 21k and my recent inspection the dealer said I have 9mm all around (I drive easy most of the time).
But either way, Mrg02d said his dealer put wrong number and had to get his brakes changed. but 45k is about right for a person that drive "normal".
I just received my pads today for my 2014 is350 F-sport brakes and the thickness is about 11mm and 9mm for where the line stops. So the 9mm on the pads are right.
I did checked the rears and they seem to be much thicker than 9mm and has about 17k miles on them. Maybe 17.2mm is for the rears. anyhow, I won't be replacing them anytime soon.
I will say that I think the brakes on the 250 F Sport seem to be oriented toward withstanding spirited drivers on the 350 F models, and in the past when I drove cars with lots of horsepower, my brake pads and rotors needed much more frequent service (if the power is there, it gets used). These days I am far from a spirited driver. It makes sense that the 250 F is much more economical on brake parts, under utilizing the equipment it has, I just don't think I could explain zero wear on the front at 21k to anyone and expect them to believe me.
