Anyone know minimum tolerances for 92' rotors?
INSPECTION AND REPAIR OF FRONT
BRAKE COMPONENTS
1. MEASURE PAD LINING THICKNESS
Using a ruler, measure the pad lining thickness.
Standard thickness: 11.0 mm (0.433 in.)
Minimum thickness: 1.0 mm (0.039 in.)
Replace the pad if the pad’s thickness is at the minimum
thickness or less, or if the pad has severely uneven wear.
2. MEASURE ROTOR DISC THICKNESS
Using a micrometer, measure the rotor disc thickness.
Standard thickness: 28.0 mm (1.102 in.)
Minimum thickness: 26.0 mm (1.024 in.)
Replace the rotor disc if the thickness of the rotor disc is at
the minimum thickness or less. Replace the rotor disc or grind
it on a lathe if it is scored or is worn unevenly
BRAKE COMPONENTS
supaIS350
Suspension and Brakes
28
04-06-08 10:42 AM
