Gs400 with supra TT caliper swap (clink noise)
Hello everyone, i just did the Supra TT caliper swap on my 98 GS400 , everything work but there a clink noise come from the front right side caliper ever time I'm on the brake..... please help
are your pads seated properly? recheck torque on caliper bolts AND lug nuts.
does it happen more frequently with speed? as in 30mph clink clink clink, 5mph clink........clink......... clink...... does it slow with speed?
just got it done last night, so pads are lest then 40 miles> the clink does happen with speed but just one time and stop , around 30mph a louder clink then 5mph...... the driver side is fine but only from the passenger , ill go home tonight and push the dust shield away from the rotor a bit and checking the end links, the car haven't drive for a while...... also noticed no clink noise when go in reverse ......
CHECK YOUR CALIPER BOLTS ASAP. Went through the same thing after i installed mine. had a loos bolt. if thats the culprit use a hight temp thread lock to keep it tight. i've been rolling on mine for about 2 years now with no issues since
