2014 IS250/350 RWD Alignment Specs
I've taken my car a couple of times to different places to get it aligned to Lexus specifications but they were unable to pull up the spec sheet for the car. So I'd figure I'd post it on here in case anyone encounters this same problem in the near future.
Front Specified Range
Camber: -1.0 to 0.5
Caster: 7.6 to 9.1
Toe: -0.13 to 0.18
Cross Camber: -0.8 to 0.8
Cross Caster: -0.8 to 0.8
Total Toe: -0.25 to 0.35
Rear Specified Range
Camber: -2.3 to -0.8
Toe: 0.00 to 0.18
Total Toe: 0.00 to 0.37
Hope this helps anyone!
Camber: -1.0 to 0.5
Caster: 7.6 to 9.1
Toe: -0.13 to 0.18
Toe: 0.00 to 0.18
Camber: -1.0 to 0.5
Caster: 7.6 to 9.1
Toe: -0.13 to 0.18
Toe: 0.00 to 0.18
Camber: -1.0 to 0.5
Caster: 7.6 to 9.1
Toe: -0.13 to 0.18
Toe: 0.00 to 0.18
Thanks
I've had an alignment at two different places and a couple of the numbers listed in the "spec range" print out vary from the numbers listed above. Both locations had the exact same spec ranges.
Specifically, front toe (-.07 to 0.12) and front total toe (-0.13 to 0.23). Everything else is exactly the same.
