Big Brakes for 1999 lexus GS400
Hi everyone! I'm new in this forum and I need your help. I have a 1999 GS400 and i'm thinking of putting big brakes on it. Any suggestions as to what brand? I like the looks of brembo and AMG but i'm looking at price around $1500. I saw stop tech too and a lot cheaper. Is it reasonable though? My concern is if i put less than $1000 yet its useless (same as the factory) then is $2000 to $3000 worth it or over kill? I've been doing online shopping but i'm hesitant. Thanks for your time guys!
5% Club. Killing it!!!
Welcome to the forums.... For a 1k or under you can go with the LS400 or Supra Big brake kit and still have better stopping power than stock... many are using the LS400 setup and love it... 4 pistons are better than two so they definitely will work. in the 1500 to 2k range your still at the 4 piston setup on most BBK.... 6 pistons are 2.5k and up...
Thank you!!! That was a relief. I'm considering Supra TT now and gonna order soon. Now I'm looking for rear rotors that would look identical to the one in front that comes with the kit. They said I can't put new rotors (rear) without getting new calipers that goes with it... And that's another pair of brake kit...smh 😒
Thank you!!! That was a relief. I'm considering Supra TT now and gonna order soon. Now I'm looking for rear rotors that would look identical to the one in front that comes with the kit. They said I can't put new rotors (rear) without getting new calipers that goes with it... And that's another pair of brake kit...smh dde12
I'm running LS400 calipers (along with many others who're running either those or Supra TT calipers), with slotted/cross-drilled rotors and ceramic pads; I have the exact same rotor/pad setup in the rear on the stock calipers.
Thanks for your help guys! I ordered SUPRA TT cal, brembo cross drilled rotors and pads. My main concern is I ordered goodrich stainless brake line specific for GS400. Now, will this fit with the supra tt calipers? I heard you put SS BRAIDED BRAKE LINE specifically modified for this SUPRA TT to GS400 upgrade. Where can I get this? Thanks again for your help!!!
Forum Administrator
Before you find out the hard way.... What wheels do you have on your GS? Are they high disk fittment up front with room for big brakes?
I'm thinking of doing upgrade also...there's lots of good information on the 2gs section here but I have not seen one where someone took the time to do a step by step with pictures of just the Ls400 set up, Supra TT set up, or aftermarket set up. I would love to see someone do this.....
