Handling
If you just want your car to feel "fresh", here would be my suggestions:
1a) Shocks if yours need replaced.
1b) You can find Sport model springs if you want to stay close to factory - personally I went with Swift Sport lowering springs, and have been happy with them. There are of course other springs, or you can go to coilovers.
2) If shocks are still good, do the front & rear sway bars next. You can get either the F-Sport, or Hotchkis (which have another adjustment hole on the rear bar). I added adjustable endlinks for the rear bar as well.
3) Quality tires will go a long way if you don't already have them - many choices depending on your needs & driving conditions.
4) Figs Engineering front lower control arm bushings. Helps to maintain your alignment settings. Can be purchased already pressed into a bracket, which makes it an easy job.
That will give you a nice handling car, and cover all the basics...
The IS-F steering ECU is nice, but is more of an improvement in how the car 'feels' (feedback) than a pure handling improvement. Also, don't forget it will need to be calibrated at the dealer if purchased new (meaning it has not been initialized yet).
Or if you can find a set of used BC coilovers, you can revalve them to be just as good or better than Ohlins by following this tutorial.
https://www.clublexus.com/forums/gs-...rts-1-3-a.html
