Do we need a DIY on springs?
Old 01-29-15, 12:21 PM
CLUM
CLUM's Avatar
Default Do we need a DIY on springs?
Is there a need for a DIY on springs? I'm going to be doing mine tonight and can write one up if needed. ?
Old 01-29-15, 12:25 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Don't think I've seen one, thanks for contributing!
Old 01-29-15, 12:32 PM
CLUM
CLUM's Avatar
no problem. yeah I searched and didn't find anything. only found one for the GS which i'm sure will be similar to the IS and what i'll be using for my guide. Only problem is I don't know the torque specs for any of the bolts...
Edit, found some torque specs posted by IS350S2K:
Torque specs:
a. Upper shock mount x3 (49 ft.lb)
b. Upper shock nut (20 ft. lb)
c. Actuator cap (14 ft.lb)
d. Ball joint nut (64 ft.lb)
e. Swaybar upper endlink nut (62 ft.lb)
f. Lower shock bolt (133 ft.lb)
g. Skid control sensor wire (10 ft.lb (shock body), 53 in.lb (fender body))
Old 01-29-15, 12:43 PM
CLUM
CLUM's Avatar
I found a semi write up (fronts only) here by IS350S2K:
https://www.clublexus.com/forums/sus...ml#post8310187
Old 01-29-15, 12:52 PM
TTechLexus
TTechLexus's Avatar
YES Please and good luck!
Old 01-29-15, 02:00 PM
CLUM
CLUM's Avatar
Thanks. I just purchased that same 2 day subscription to the repair manuals that IS350S2K did, so I have all the torque specs and instructions. I'll do the install tonight and do a proper write up this weekend.
NEbiker10
11-29-12 05:01 PM
MyIS350G
Suspension and Brakes
09-22-10 07:41 PM
Sc4Love
SC- 1st Gen (1992-2000)
04-29-10 09:18 AM
LudeNsoL
01-22-10 06:42 PM
Kendhal
03-09-04 06:16 AM
Quick Reply: Do we need a DIY on springs?
