Rotora BBK issue
Old 07-22-14, 01:18 PM
jmecbr900
jmecbr900's Avatar
Default Rotora BBK issue
I'm having a normally simple issue with my Rotora BBK's.
Seems they no longer carry the 4 pot BBK's and for some reason that means they don't carry the replacement rotors that go with it. I can get the pads no problem, but can't get the rotors any where.
Well, mine are getting around the time to change them out. I've never changed them out before.
Has anyone ran into this issue or have suggestions on how to get around it. I don't want to invest in another BBK just because the rotors. There's nothing wrong with the ones I have now.
From my research, the issue is clearance. I can't just slap any old rotor and it work.
Any ideas or help would be appreciated.
Old 07-24-14, 03:18 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I believe L-tuned.com sells the replacements but I'll have to search later for more info. heading out
Old 07-24-14, 05:05 PM
tiger4life
tiger4life's Avatar
Sorry I don't have an answer for you, but this is the exact reason why I want my future bbk to center around ISF rotors and some type of OEM caliper.
Old 07-24-14, 05:09 PM
tiger4life
tiger4life's Avatar
Are they two piece rotors? If so, you can remove the hat and just buy rotor rings.
Old 07-24-14, 05:18 PM
Need4Speed
Former Sponsor
Need4Speed's Avatar
If I am not mistaken they are 2 piece rotors
Old 07-25-14, 09:20 AM
jmecbr900
jmecbr900's Avatar
Sorry guys, it's the one piece rotors on there now, although I would buy 2 piece rotors at this point. I don't care. I just don't want to have to throw away my BBK just because Rotora decided in their infinite wisdom to not offer an alternative for older models like mine.
I will take any rotors that will work at this point. They're not falling apart or anything. I still drive the car, but I can feel they're starting to warp and to be honest I can't complain about that since I've never turned them since I got them eons ago. Thing is that since they're slotted and drilled and now worn, nobody is going to attempt to turn them. Not worth the headache at this point to do that, so I'm searching for just replacing the rotors since the calipers eventhough they're not the latest and greatest of course are still working perfectly.
Old 07-25-14, 09:39 AM
tiger4life
tiger4life's Avatar
You'll just have to measure the following:
hat height
rotor thickness
rotor diameter
The hub opening is 62mm. Then you'll have to contact other manufacturers and see if they have a similar rotor in 5x114. Contact Futura, Brembo, Wilwood, etc...
Old 07-25-14, 10:07 PM
AVSRacing
AVSRacing's Avatar
damn, this is one of my biggest worries when doing aftermarket brakes
sakon3
17
06-11-20 02:17 PM
leica
09-20-18 01:14 PM
ak11
Wheels, Tires & Brakes Forum
10-10-14 07:17 AM
skitallz
IS F (2008-2014)
15
02-16-11 05:41 AM
MarkGS400
Suspension and Brakes
09-03-09 05:13 AM
Quick Reply: Rotora BBK issue
