help. squeak noise coming from front drivers side wheel well
Old 07-01-14, 10:07 AM
rockyvo09
rockyvo09's Avatar
Default help. squeak noise coming from front drivers side wheel well
Hi CL,
I just had a question and needed some opinions. I have an 08 RWD 350 with about 98k miles on it. Recently I noticed a squeaking noise coming from the drivers side front wheel well whenever I go over bumps, take turns, or even during braking.
I checked it out and noticed that the dust boot on the shock was torn. Initially I thought the shock might have gone out since I'm about at 100k miles, but I didn't see any visible oil leaking or running down the body of the shock.
About 3 months ago I installed an spc adjustable ball joint for that side of my car. I checked that and it seems okay.
What do you guys think it is? I thought either a blown shock or the upper control arm squeaking. Any advice would be helpful.
Thanks in advance for your input.
Old 07-01-14, 12:27 PM
Gville350
Gville350's Avatar
Lube all joints you can and see if the sound continues. Could very well be a bad shock.
Old 07-01-14, 12:42 PM
Mike_1GO
Mike_1GO's Avatar
if its a squeak it could very well be a rubber bushing. best way to tell would be to remove the wheel and inspect for any cracked or torn bushings.
Old 07-19-14, 03:52 PM
jmoya59
jmoya59's Avatar
Dude I got the same problem.In my ase start doing squeaking noise at soon i install the spc camber kit, I'm going to get Godspeed camber kit
Old 07-19-14, 04:38 PM
jmoya59
jmoya59's Avatar
Ok I think I got a solution, I just put motorcycle chain lube on control arm and ball joints,no squeaking noises, I might have to do this 2 times a months... I let you know dude, by the way motorcycle chain lube is only 9.99 at Walmart
Old 07-23-14, 09:48 AM
rockyvo09
rockyvo09's Avatar
Yeah I lubed both up a couple of days ago like Gville350 suggested and it seemed to go away and reduce the squeak. I think it might have been the upper control arm. I moved it around a lot while installing the ball joint. Hopefully that'll fix it. Thanks for your advice
Old 07-23-14, 05:57 PM
Gville350
Gville350's Avatar
I should have also suggested my grease of choice, automotive white lithium grease (oil-based). But glad to hear the noises going away!
Old 07-28-14, 03:24 AM
jmoya59
jmoya59's Avatar
Default Camber noise
I took my car to the guy install the camber kit,one of the camber was install wrong, noise is gone, check the angle on the camber, that was my problem. Camber was install on a wrong angle
Old 10-13-14, 09:12 PM
rockyvo09
rockyvo09's Avatar
Just wanted to update, I replaced the bushings on the sway bar when I installed the f sport sway bar and they were indeed cracked and dry. Once I installed the new ones the squeaking stopped. The squeak came back after greasing so it wasn't the upper control arm or ball joint, just the bushings as mike said.
Old 11-03-14, 12:01 PM
Sleekper
Sleekper's Avatar
Default Bushing Part Number
I am getting a squeak from my front driver side as well. Can you please let me know what replacement bushing you used for the F sport front sway bar? If you used the F Sport one can you let me know the part number? I'm thinking about going aftermarket so I can add grease to it. What do you guys suggest? Thanks!
Old 03-30-15, 07:21 AM
CiscoIS350
CiscoIS350's Avatar
Default Same problem with the noise on the driver side
I have the same issue with the noise on the driver side after installing the SPC camber kit ... I was thinking on switching it to the other side to see if it is indeed the SPC part.. as I think is coming from there (see video)... OEM sway bar.. F-Sports Springs is the only mod to the suspension besides the SPC camber. The car is sitting on 20's.
So, has any figured out which bushing or if its the camber?/?
tzxlyd
Suspension and Brakes
08-06-16 09:17 AM
jay90011
11-16-12 02:01 PM
melissac
04-01-11 09:21 AM
ta1972
04-05-08 02:11 PM
Quick Reply: help. squeak noise coming from front drivers side wheel well
