Camber and coilovers problems??
Old 03-16-14, 11:17 AM
ATran408
ATran408's Avatar
Default Camber and coilovers problems??
So I been really stressing over this problem. my BC coilovers came home 2 weeks ago and I haven't decided to put it on yet cause I'm still shopping for 19' wheels. I was told that I will still need to get camber just in case anything happen. Another person told me that my BC coilovers have camber built it. Can someone tell me what should I do?? I'm not trying to go way to low and I'm also going to get my fenders rolled. So what do you guys prefer and what wheel size should I get.
Old 03-16-14, 01:09 PM
1sWt2GS
1sWt2GS's Avatar
lol.... what are you asking?
how do you "get" camber and how is camber "built in?"
Old 03-16-14, 02:22 PM
VIP161
VIP161's Avatar
What you were told was bull****. I am running BC coils as low as the car can go, sometimes spinning a rear wheel just to get up a driveway. To make a long story short, I was able to get my alignment done within specs considering how low I am. I live near you. Take your GS to Vex Motorsports. I wasn't expecting miracles but they made it work. It's been 15,000 since the alignment and my tires are not showing any signs of uneven wear.
Old 03-18-14, 11:12 PM
ATran408
ATran408's Avatar
Did you also get camber? What's your setup and size wheels you running??
Old 03-20-14, 09:20 AM
RikTT
RikTT's Avatar
BC's do not have the camber adjustments built into them. You have to get upper control arms with camber adjustments if you are concerned about that.
The lower you go, the more negative the camber gets so it really depends on your final ride height and if you need aftermarket camber arms to be within oem spec and saving your tires.
Old 04-01-14, 12:47 PM
1KhpWrx
1KhpWrx's Avatar
camber isn't something you buy
if you look at the car from the rear
/---\ negative camber
\---/ positive camber
Old 04-03-14, 03:04 PM
youngs3oo
youngs3oo's Avatar
What's your offsets? That plays a big part so that info is needed. From what I've heard BC's are good. If you dont plan on going too low, then you might be able to be within factory specs. Sometimes the best way is to just do it and learn.
zrs6v4
Suspension and Brakes
19
11-04-15 11:47 AM
Chris1020
04-01-13 11:28 AM
snaggle
13
11-28-12 07:00 PM
melski415
01-27-12 10:56 AM
slowdiver
02-07-11 10:31 PM
Quick Reply: Camber and coilovers problems??
