New upper ball joint leaking
Old 10-10-13, 06:41 PM
DND
DND's Avatar
Default New upper ball joint leaking
Well this is a bummer.. After installing brand new OEM upper ball joints two weeks ago, the drivers side ball joint is leaking a bit. Is it possible it's just a little extra grease that's leaking out? Noticed it today. Not sure if I should be worried or just leave it alone. Spent a good chunk of money to keep everything stock, now sort of regretting that.
I got the control arms off of ebay, from a legit seller (appears to be at least) about a $100 cheaper than what sewell charges for them (with the CL discount). I guess my concern is while they do say the parts come with a 1 year manufacturers warranty, would it be an issue since I installed them myself?
Old 10-16-13, 08:02 AM
Sampak
Sampak's Avatar
The only way to find out is to wipe the excess grease off the rubber boots on the one in question, and observe after you drive around some. If it's a torn boot, then as long as you can approach someone at Lexus or the parts supplier, you should be able to exchange it under warranty, at least that's what logic tells me. I don't think you installing it should void that (unless they can prove that you damaged it and tore something during the install, I imagine).
Old 10-18-13, 04:53 AM
MasterKwan
MasterKwan's Avatar
Wonder if it could be Lexus arms with crappy chinese knock off balljoints? You can find balljoint replacements for most Lexus control arms but, they're not Lexus balljoints. Did you compare the old with the new balljoints? Particularly the quality of the rubber boots.
yotoy822
09-08-18 10:07 AM
fly_s2k
11-23-14 08:25 PM
MikeFoxx
Suspension and Brakes
42
11-07-11 09:06 PM
BP_VVt-i
08-29-09 12:26 PM
Cannonbear
06-26-05 10:37 AM
Quick Reply: New upper ball joint leaking
