GS300 Alignment
GS300 Alignment
Last week I ran across a post about alignment on GS warning about making sure a particular fastener was tightened properly after alignment. I spent 3 hours yesterday searching the CL site and have not been able to find it!
Has anyone seen this? Just did ball joints, outer tie rods, caster arm bushings, steering bushings and put new Michelins on and I want to make sure alignment is done right. I'll keep looking but time is getting tight; I think post may have even been from Jeff Tsai.
Appreciate the help; everything listed above as replaced was done on advice from you all!
Here you go
https://www.clublexus.com/forums/gs-...-problems.html
Sometime you better off google it then search within the forum. The search and advance search is somewhat in need of a fine tune up.
Thanks for the link. I just drove this car from Michigan to California, what a ride! What a car, 27-28 mpg on 91 Octane and most of that at 80 mph with the AC one. I'm going to have Lexus throw it up on the lift and make sure everything looks OK, good shop here in San Diego. I'll make sure they torque down that bolt!
Ahheck01
Suspension and Brakes
02-12-15 07:00 PM
