Assistance with removal of OEM trac-link bushings
Old 05-26-13, 09:34 PM
BayAreaLex
BayAreaLex's Avatar
Default Assistance with removal of OEM trac-link bushings
Hi guys,
I am hoping someone can steer me in the right direction.
I am attempting to remove the OEM trac-link bushings (I did the knuckle/carrier bushings today and everything went smooth - I pressed those out).
However, with the trac-link bushings, the dust shields are in the way and I don't see an easy way to remove those from what I can see with the rotors/calipers off.
Does anyone have any recommendations? The trac-link bushings don't have nearly as much working room as the carrier/knuckle bushings do. I can't press them out like I did the carrier/knuckle bushings since I don't have the room.
Old 05-26-13, 09:47 PM
kamikaze04
kamikaze04's Avatar
Hmm....that's a tough one. Maybe you would have to take off the dust shield, rotor, and the caliper to get to it. I do not see any other way that would work.
Old 05-26-13, 09:56 PM
BayAreaLex
BayAreaLex's Avatar
I don't mind removing the shields. Problem is I don't see an obvious way to get them off.
What's keeping those shields on?
Old 08-04-13, 05:42 AM
christodav
christodav's Avatar
I used a balljoint removal tool made by SPC. The c-clamp has an end on it that fits perfectly. You will also need a rattle gun.
Figs Engineering sell the tool from their website.
Chris
Old 08-04-13, 04:12 PM
LuxuryGS3
LuxuryGS3's Avatar
Hey man you dont need anything special. Just use an impact gun if you have if not just use a ratchet and a rubber mallet to break it loose. No special tool needed brother.
And take off the wheel sir. Makes it so much easier to work under there.
Old 08-07-13, 05:55 AM
christodav
christodav's Avatar
Yeh man and pigs fly....
Old 08-07-13, 09:49 AM
LuxuryGS3
LuxuryGS3's Avatar
No need to be rude. I misread the thread and thought he was talking about the traction link itself and not the bushing. My fault.
Old 08-08-13, 01:48 AM
christodav
christodav's Avatar
No problem - sorry for coming across rude.
Chris
Old 08-08-13, 07:18 AM
LuxuryGS3
LuxuryGS3's Avatar
Chris
All good. Just a user error on my part is all.
Old 08-08-13, 08:48 AM
Trevstuh
Trevstuh's Avatar
I would just undo everything to get to the bushing. But from what I remember is the sheild is apart of the whole spindle I do believe.
en11871
02-26-08 08:27 PM
nthach
10-03-07 02:50 PM
RacingLuxury
Suspension and Brakes
07-23-07 10:45 AM
narfy
01-03-07 01:29 PM
NICKGS4
02-06-05 10:41 PM
Quick Reply: Assistance with removal of OEM trac-link bushings
