lost power streeing
Old 03-22-13, 07:13 PM
rickytsui
rickytsui's Avatar
Default lost power streeing
ok after the swap i lost my power streeing and i put in new rack and new pump BUT when i sent out my wire to get it redone it didnt come back with the plug for the rack what should i do now ?
ricky
Old 03-25-13, 01:39 PM
k7q
k7q's Avatar
That sensor on the rack wouldn't make you lose power steering completely. If the power steering was working before the swap, it sounds like the problem was the pump.
Did you bleed the power steering ? Maybe try another pump.
Old 03-25-13, 03:22 PM
rickytsui
rickytsui's Avatar
i try 3 pumps already
Old 03-25-13, 03:26 PM
rickytsui
rickytsui's Avatar
can it be maybe i ran the soft hose wrong?
Old 03-25-13, 05:31 PM
k7q
k7q's Avatar
are you losing power steering fluid? could be a defective rack.
Old 03-25-13, 06:34 PM
rickytsui
rickytsui's Avatar
i dont think so it was a reman rack that i got and im not losing any fluid
Old 03-25-13, 07:10 PM
k7q
k7q's Avatar
i dont know if you want to try this but, #44330. that can get stuck and cause you to dont have any power. this happened to me once. i was told to sand around it a little with fine sandpaper.
Old 03-25-13, 07:26 PM
rickytsui
rickytsui's Avatar
when i swap out the pump i clean that part already but the pics you post up was a 2jzge PS setup
Old 03-25-13, 07:33 PM
k7q
k7q's Avatar
not sure what else it can be, im stumped.
Old 04-05-13, 12:30 PM
mikevandam
mikevandam's Avatar
check your hoses. return lines and pressure lines.
Old 07-24-13, 09:34 AM
IIJZSC300
IIJZSC300's Avatar
So did u figure it out having the same issue after my swap
OMAHA
20
01-05-19 12:57 AM
Dx3
Suspension and Brakes
32
04-07-13 07:36 AM
eliteskill
SC- 1st Gen (1992-2000)
07-09-11 11:22 PM
Shaar
Performance & Maintenance
07-15-08 10:58 AM
lsflame
11-21-06 05:59 AM
Quick Reply: lost power streeing
