Need help identifying part
Old 07-30-12, 09:40 AM
sputniknyc
sputniknyc's Avatar
Default Need help identifying part
Shop could not complete alignment on rear right side.
Tech said I needed a new bolt in order to correctly do wheel alignment.
thanks all
Old 07-30-12, 09:22 PM
SorrGwa
SorrGwa's Avatar
rear toe link alignment bolt
48194B 4819830080
48194H 4819030060
they call it a cam bolt, but its the rear toe
ordered most of my oem parts from sewell, hasnt missed a beat yet.
if you have aftermarket suspension, might want to look into figs. gives me range for alignment.
http://lexus.sewellparts.com/oem-cat...S430-2001.html
Old 07-30-12, 09:53 PM
sputniknyc
sputniknyc's Avatar
do I need 90170-12030(2)????
thanks!
Old 07-31-12, 05:21 AM
77i9
77i9's Avatar
90170-12030(2) is just the lock nut
you will also need 48194B and 48198H
like SorrGwa mentioned above
Old 07-31-12, 09:14 AM
sputniknyc
sputniknyc's Avatar
thank you all!!
just ordered from sewell with the GREAT CL DISCOUNT!
how hard is it to change this nut and bolt?
Old 07-31-12, 10:48 AM
geeznuts
geeznuts's Avatar
You should by some adjustable toe arms. So you can get it dialed in better
Old 07-31-12, 10:49 AM
geeznuts
geeznuts's Avatar
Originally Posted by sputniknyc
thank you all!!
Very easy to change the bolt. Unless its stripped.
Old 07-31-12, 02:29 PM
77i9
77i9's Avatar
OP I suggest you buy a fairly sized breaker bar if u don't already have one, and some wd40.
those bolts looked pretty rusted
Old 07-31-12, 08:46 PM
2eXceL
2eXceL's Avatar
The bolt in the pic looks like its gonna be seized up pretty good, try PB Blaster, I feel it works better than WD40 (+1 on the Breaker bar)
lextout
Suspension and Brakes
03-13-15 09:48 PM
seivonecsu
10-10-12 12:16 PM
Fahmed
08-07-12 05:24 PM
ChiChiMan
14
09-17-11 06:37 PM
fireballs gs400
Maintenance
08-14-06 01:18 PM
Quick Reply: Need help identifying part
