Need Air Ride Guru's. Piecing System Together?
ill tell u this, do it once and do it right. you will be better off.
costs more up front but saves u more money in the end
i have UAS setup with bilstein shocks. VU4 and e-level installed
its a good setup, but i would now go for Airrex struts and accuair setup together
UAS has too much rubbing issues.......
Believe me fellas, I'm all about doing it right the first time. I might just stick to ordering my custom BC coils first, and when I finally decide to go air, just get UAS bags to slip over the BC struts with a bracket kit. Will probably go Accuair for the manifold as well. What are some popular compressors/5 gal tanks/lines people run with this sort of set up? Stainless steel I presume to avoid rusting?
them air rex works perfects.........i think haha i havent driven the car since the install since my car been in the body shop for a few weeks. i test it out up and down with any rubbing issue but i did come to find out that the rear sleeve bags do come close to rubbing but on a 1-2cm cleareance.. so i ended up bangin the sidewall of the chasis to get more of a clearance. just a heads up other than that i well built kit for the time being.
I can get it for $1150.00 shipped. The management pack is universal. All that you have to do is add your own bags/struts coils and you are done.
LOOK HERE
This system is amazing. No cutting required. There are only 3 wires to be connected. I have literally spent more time installing a car radio than this system.
This is what it comes with
LOOK HERE
LOOK HERE
LOOK HERE
http://bagriders.com/modlab/products...TOUCH-PAD.html
This kit with the airrex struts might be the best idea yet. They do have brackets for the 2gen gs. 270$front and rear together and the bags are 165 each so for 930$ could work.
Where can one get just the Airrex struts?
I'm more interested what price you could get us for this kit. They asking 2000$
http://liberty-vip.com/forum/showthr...ir-E-Level-Kit
brand new, just taken out of the box for pics.
