Buzzing sound when I step on brakes..
Old 11-03-11, 06:10 PM
Tank
Tank's Avatar
Default Buzzing sound when I step on brakes..
Hello all,
I get a buzzing sound when Im turning the wheel to the left while slowing down to stop, then I feel a clicking vibration comming from the brake pedal any Idea what could be malfunctioning? traction control? ABS?
Thanks in advance.
UPDATE TO THIS COMMON PROBLEM IN THIS THREAD: https://www.clublexus.com/forums/gs-...s-problem.html
THIS IS WHAT WORKED FOR ME. THERE ARE OTHER THREADS THAT TALK ABOUT SPEED SENSOR CABLE BEING STRETCHED DUE TO LOWER RIDE HEIGHT CAUSING MALFUNCTIONS AS WELL.
Old 11-03-11, 10:16 PM
gsCrazy
gsCrazy's Avatar
sounds like either your abs sensor is bad or there's some crud in there... i'm experiencing the same issue right now but when i turn right. my mech cleaned out where the abs sensor goes into on the right side and it has improved but still clicks.
the clicks/buzz is the abs kicking in i believe. anyone else experience this? what fixed it?
Old 11-03-11, 11:34 PM
GS4_Fiend
GS4_Fiend's Avatar
If you ABS light is not on, I wouldn't be to worried. The ABS system checks for any malfunction everytime. That's why you feel your brake pedal vibrating because the ABS motor is activating and self checking itself. I say it's normal.
Old 11-04-11, 12:32 PM
Tank
Tank's Avatar
Allthough your right about the ABS light and the self checks, its not normal for it to engage under such circumstances. ABS checks it's self when you turn the key not cause your turning right and slowing down. the only thing that you can hear check it self at intervals during operation is the traction control.
it's gotta be either one of the two. I am gonna try to clean the ABS speed sensor, and check for lose wires etc. just hope it's not a PITA to find that problem cause it's definately not normal.
Thanks for ur input
Old 11-09-11, 10:04 PM
kit cat
kit cat's Avatar
it's gotta be either one of the two. I am gonna try to clean the ABS speed sensor, and check for lose wires etc. just hope it's not a PITA to find that problem cause it's definitely not normal.
Thanks for ur input
My car is starting to do the exact same thing lately. It's only at crawling speed and when the wheel is turned also.
I am guessing its the speed sensor also. I think some scantools can scan the VSC codes (but can't clear them). Hopefully it can tell me what is faulty.
Old 02-23-12, 06:50 PM
gsCrazy
gsCrazy's Avatar
i've had this issue since last november as well.. has anyone here found the fix?
Old 02-24-12, 11:45 AM
repugnante
repugnante's Avatar
BMC maybe crapping out on you
Old 02-27-12, 08:17 AM
gsCrazy
gsCrazy's Avatar
I've been reading other posts and it seems like it just might be the pump of the bmc. Seems to be a common issue. Also if it were the bmc shouldn't you also have a soft pedal that doesn't come back up after being pressed?
Old 02-28-12, 09:44 AM
repugnante
repugnante's Avatar
^ not all the time. With these cars, the trend seems to be lack of firmness or pedal feel
Old 03-01-12, 07:39 PM
Tank
Tank's Avatar
I'm gonna try the speed sensor first hopefully thats it.. by the way whats a BMC?..lol haven't figured out the acronym..
Old 03-01-12, 07:43 PM
02Legend
02Legend's Avatar
Brake Master Cylinder
Old 03-01-12, 07:46 PM
Tank
Tank's Avatar
lol, thanx
Old 04-14-12, 06:29 PM
gsCrazy
gsCrazy's Avatar
lol, thanx
were you ever able to get this fixed, eskaeone?
Old 08-15-13, 12:08 AM
Tank
Tank's Avatar
back from the dead, nope I tried switching out the driver's side ABS sensor, but it still malfunctioned I'm waiting to take the GS to my pal whom has a snap-on scanner. hopefully he can narrow it down instead of me throwing parts at it..
Old 07-14-14, 03:47 PM
Unbreakabl
Unbreakabl's Avatar
Any fix to this issue?
Quick Reply: Buzzing sound when I step on brakes..
