LS Brakes
Old 08-16-14, 09:14 AM
  #181
Dougspeed
Dougspeed's Avatar
The 98-00 16" oem SC wheels do fit, but you need at least a 20mm spacer AND you must use the clip on style wheel weights instead of the more commonly used tape style weights when the wheels are balanced as it's a tight fit.
Old 08-17-14, 12:46 AM
  #182
irondonkey
irondonkey's Avatar
anyone here work at a machine shop?
part number- 89047727 at rockauto.com
those are CTSV 4 pot calipers.
now... we just need someone to produce the brackets. it uses a 350Z rotor. the guy has been making brackets for all sorts of cars, just not the SC.
some people are even using SRT brembo's. if you want to blow the extra money, you can get a 6 pot brake system fitted on.
Old 08-17-14, 09:28 AM
  #183
OG Dada
OG Dada's Avatar
^^^You might wanna start a new thread, because this thread clearly says LS brakes.
Old 08-17-14, 03:21 PM
  #184
irondonkey
irondonkey's Avatar
that's cool. it's still a thread about brake upgrades for SC's.
Old 08-17-14, 04:24 PM
  #185
t2d2
t2d2's Avatar
You guys both have good points, no need for misunderstanding and disagreement... On the one hand, alternatives to LS400 kits are very relevant to a thread on upgrading stock SC brakes. On the other hand, starting a new thread makes sense so that information doesn't get lost in a thread where people are only looking for LS info.
Old 09-22-14, 03:19 PM
  #186
dw2k1
dw2k1's Avatar
Since we are talking about LS brakes, does anyone know the torque setting for the 4 Torx bolt that holds the caliper together?
Thanks in advance!
Old 12-24-14, 02:29 PM
  #187
Kris9884
Kris9884's Avatar
Ah so it CAN be done! I have a LS setup sitting in the garage, just cant fit them without spacers or other wheels..
Old 02-03-16, 06:42 PM
  #188
Suplex432
Suplex432's Avatar
I have these on my 1997 as well, so they will fit? And what clip on style wheel
Weights?
Old 02-04-16, 09:56 AM
  #189
Blkexcoupe
Blkexcoupe's Avatar
Weights?
You'll need a spacer for them to fit. I think 15mm is the bare minimum, but 20mm would be better.
Clip on weights are a must. Clip on weights "clip on" to the face of the rim. They're commonly used on steel rims.
The other type of wheel weight is tape weights that are glued on to the back inside the barrel of the rim. Tape weights will hit the brake caliper during rotation, so it doesn't work.
jdog0411
10-05-11 04:19 PM
ZenkiS14
Suspension and Brakes
13
07-18-09 11:05 AM
Richardim
19
08-31-07 11:48 AM
acenase
02-11-07 08:17 PM
aliga
04-15-04 07:56 PM
Quick Reply: LS Brakes
