99 GS300-Rear calipers are leaking while bleeding front?
Old 01-08-11, 04:18 PM
toyotero
toyotero's Avatar
Default 99 GS300-Rear calipers are leaking while bleeding front?
I replaced my front rotors on my 99 GS300 and brake pads today, i bled the system how i normally bleed my other cars; Have the wife turn the ignition to on and pump the brakes while i turn the bleeder but to release air. After doing this my rear calipers started leaking brake fluid. What im i doing wrong? This is my first Lexus , but ive owned a Infinity QX56 and bleed the system the same way and had no problems. Thanks.
Old 01-08-11, 04:41 PM
toyotero
toyotero's Avatar
I believe that my problem is that i turned on the ignition when i bled the fronts and thats what caused the rear to leak. I found this post and its very helpful. https://www.clublexus.com/forums/gs-...-bleeding.html
Old 01-08-11, 07:59 PM
masagsxr
masagsxr's Avatar
I don't see how turning ON the ignition will cause any to leak.... Sometimes I turn the car "ON" itself when I work on one. Why you ask? because, some ABS system do not open up. When the vehicle is "OFF" and you try to bleed the brake, you might not be able to bleed that particular line because the valve from the ABS is close preventing the fluid to go through that line.
Old 01-08-11, 10:28 PM
PHML
Master Thread Closer!!
PHML's Avatar
turning the ignition to the ON position should activate the brake booster on the 2GS....you should hear a pumping sound....like a mini compressor under the brake fluid reservoir....so having your wife pump the brakes to bleed is NOT necessary.
having a leak in the rear caliper is a separate problem. see if you can locate where the leak if from....on the line itself...or at the connection. I suspect it may be a missing crush washer, a loose connection, or even the seals in the piston being worn and requires replacement with a brake caliper repair kit.
good luck.
Old 01-09-11, 10:20 AM
toyotero
toyotero's Avatar
good luck.
I bought more brake fluid today and bled the fronts with the ignition off, went to the back and had my wife turn the ignition to on position press one time on the brakes while i bled the rear brakes. Im still leaking from the rear calipers piston seals. I guess its time to replace them, more money!
Old 01-09-11, 01:32 PM
masagsxr
masagsxr's Avatar
Glad you found the problem.. That certainly don't have anything to do with having the ignition ON or OFF buddy. It would/should leak even if the ignition is on OFF since your seals are worn out. The seals are cheap. Probably $20-30 and the rest will just be lots of time and labor. Hey, quality time working with your wife right? Priceless!!!!
Old 01-09-11, 03:58 PM
toyotero
toyotero's Avatar
Tell me about it! I seen the writeup to rebuild the caliper and it doesn't seem that hard. I'm going to the dealer tomorrow to get the kit.
Old 01-09-11, 05:50 PM
porn-adkt
porn-adkt's Avatar
Though you found the problem, your still bleeding it wrong..Im wondering how many pumps before your Booster locks without the ignition on.
Old 01-09-11, 06:00 PM
PHML
PHML's Avatar
Probably a goog idea to repair each caliper's seals....btw, make sure to lube the pistons well.
Old 01-12-11, 04:07 PM
toyotero
toyotero's Avatar
I replaced my calipers and im still having some issues. I bleed them like then link i posted( Start with the rear passenger with the igniton ON have someone press on the brakes while i bleed , next i did the drivers rear same as other rear, bleed the front passenger with ignition off and lastly drivers front with the ignition off) Im no longer leaking on the rear but the front calipers are sticking somewhat, i can hear them scraping the front rotors while i drive slow and i can feel the car slowing down when i releace the gas pedal. What im i doing wrong? Do these cars have to bleed at the dealer or what? Ive never had this problem, not even my s2000.Thanks
Old 01-12-11, 04:17 PM
porn-adkt
porn-adkt's Avatar
Originally Posted by toyotero
I rear calipers and im still having some issues. I bleed them like then link i posted( Start with the rear passenger with the igniton ON have someone press on the brakes while i bleed , next i did the drivers rear same as other rear, bleed the front passenger with ignition off and lastly drivers front with the ignition off) Im no longer leaking on the rear but the front calipers are sticking somewhat, i can hear them scraping the front rotors while i drive slow and i can feel the car slowing down when i releace the gas pedal. What im i doing wrong? Do these cars have to bleed at the dealer or what? Ive never had this problem, not even my s2000.Thanks
1. still bleeding it wrong
2.Bleeding has nothing to do with Sticking pistons, check ur calipers.
3.Can not compare a GS to a S2k. Specially the POS GS master cyl/abs/booster unit.
Old 01-12-11, 04:31 PM
toyotero
toyotero's Avatar
You've told me twice that im bleeding it wrong, but not once have you told me how to bleed it. Theres a few members sayign different ways to bleed the GS, the method i used seemed to be the one more comonly used. I really care less on what crappy brake system them s2k has , all i know its stops in a dime.
Old 01-12-11, 04:51 PM
porn-adkt
porn-adkt's Avatar
whos talking about S2k brakes? either way i will now exit your thread cause what do i know. Good luck
Old 01-12-11, 04:55 PM
toyotero
toyotero's Avatar
Thanks , your doing me a favor master mechanic.
Old 01-12-11, 05:20 PM
Agent0024
Agent0024's Avatar
He's talking about the crappy GSXXX's master-cylinder/ABS unit, not the S2000.
1999sc300
Suspension and Brakes
06-30-17 10:12 PM
peasodos
06-23-17 12:36 PM
decypher
17
06-21-11 06:48 PM
costanza
Maintenance
08-17-10 03:16 PM
dcentric
09-20-06 08:16 AM
Quick Reply: 99 GS300-Rear calipers are leaking while bleeding front?
