Warning lights on
Old 09-27-10, 05:04 AM
GS4nicate
GS4nicate's Avatar
Default Warning lights on
Lower ball joint snapped in half while i was driving. Got new ones and replaced them. Now my ABS, VSC and VSC OFF light are on.
Tried reseting the ecu by unplugging the battery to see if they would go off. No luck. Ill probly just run to autozone or whatever to see if they can clear the codes, but i want to make sure there isnt an actual problem somewhere.
Did anyone else have this problem?
Old 09-27-10, 09:41 AM
Infamous 1
Infamous 1's Avatar
Check to see if you snapped the wire for the speed sensor wire.
Old 09-27-10, 12:11 PM
GS4nicate
GS4nicate's Avatar
The speed sensor wires on both sides are intact. I wonder if somehow the sensor got damaged in the process of the wheel ripping sideways...
Old 09-29-10, 02:36 PM
LamboGS3
LamboGS3's Avatar
on the outside, the sensor might look ok but on the inside, the sensor wire might of snapped already but can see with the naked eye..mostlikely its the abs sensor. change both to new ones and the light should turn off.
Old 09-29-10, 02:51 PM
sakataj
sakataj's Avatar
when Infamous 1 says check them he's implying you check for OHM'S to see if you have continuity not by physically looking at them
my guess is a wire in them probably has ripped away
replace them if you cant fix them....there are a few DIY's on fixing them on here
Luciefer
Suspension and Brakes
06-27-16 01:39 PM
peewhy
04-12-10 02:28 AM
danny10989
12-04-08 05:12 PM
Quick Reply: Warning lights on
