Installing BC Coilovers Tonight--Anything I should watch for?
Hey guys,
I'm installing my new BC coilovers tonight on my 2GS 400. I'm working with a friend who knows cars pretty well and has a lift but doesn't know much about the suspension on the GSs so I'm doing as much research as I can to know how to make the job go more smoothly.
Got any pointers???
Thanks!
Got any pointers???
Thanks!
Just be careful with the bolts, some of them are very tricky and can be extremely easy to strip. One of my buddies stripped one of his lower bolt cavities and got lucky to have just enough thread to set it and turn a couple rotations. Had he not been fortuitous it would have been a pain in the *** fixing that little situation.
Have a lot of PB blaster on hand and remember it's ok to curse at the car and take a breather for a minute
Just figured out how to multi-quote Sorry for the above thread clutter... Anyway...
LOL! I just read that to my wife and she said, "I don't get it..." Oh well, glad I didn't marry her for her Lexus knowledge!!
I'll pick up some PB on my way. Never hurts to have a good bit of that around. Good idea!
Thanks for the encouragement. I've already removed the trunk liner to expose the mounts and I'm feeling pretty good about the install.
when you drop your car you will probably have to adjust these sensors so it doesnt give you an error.
you will see a wire there will be a sensor with a bar thats perfectly 90 degrees!!!! i believe the front is on the control arm and the rear one is around the strut bar.
If you lower the car evenly all around, you won't have to adjust the headlight sensors at all. Even if you are off a few mm, the difference is pretty small considering they are constantly adjusting as you drive. That is unless you drive on perfectly flat road
And don't forget to reset the bushings before torquing the suspension bolts. It is very crucial. It's not necessary wait for the springs to 'settle'. Spring settling is BS anyways so you can get an alignment done within 1-2 days if you'd like..
So far, this is my checklist...
1. Be very careful with the ABS line when taking it off the old strut and reinstalling it on the new one. Make sure I turn the steering wheel back and forth before putting the wheels on to ensure I have enough slack in the ABS line. I suppose this is so it doesn't snap or pull out of the connector.
2. Be aware of the levelers and try to reinstall them on the new coilovers as level as possible.
3. Use plenty of penetrating oil so the bolts come out easy and make sure not to strip when reinstalling them.
4. Watch out for fat chicks wanting a ride after the coilovers are on....
5. Reset the bushings
Thanks guys...anything else feel free to post. I'm leaving around 8:20EST and I'll be sure to post up a report tomorrow after the job is done.
