Go Back   Club Lexus Forums > Lexus Model Forums > SC Models > SC 400/300 > Suspension and Brakes
Thread Tools Display Modes
Old 10-30-09, 06:44 PM   #1
KC95SC400
Trader Score: (0)
KC95SC400's Avatar
Default Will Supra bushings fit SC control arms?
I really need to replace my control arm bushings. Don't have the normal clunking problem. My issue is that the camber / caster bolts are seized to the inner sleeves of the bushings making it impossible to align the car 100%
So the question is will Supra bushings work in the SC arms? I ask because MVPMotorsports has both a front and rear kits for 189 each. The front kit does both upper and lower front arms and the rear kit does both upper and lower rear arms.
Seems like a good deal if they will work.
KC
__________________
Vortech supercharged 95 Lexus SC400. 11psi non intercooled with water / meth injection.
Best 1/4 Darlington dragway 9/16/09 12.516 (1/8 8.058)
Best 1/8 9/11/09 Mooresville dragway 7.874
Videos = http://www.youtube.com/profile?user=...00&view=videos
http://clublexus.com/forums/showthread.php?t=312268
KC95SC400 is offline   Reply With Quote
Old 10-30-09, 07:19 PM   #2
5sp_jzz30
Trader Score: (2)
5sp_jzz30's Avatar
look into kits from prothane.
i got mine, both front and rear, for 160 shipped.
__________________
5sp_jzz30 is offline   Reply With Quote
Old 10-31-09, 07:00 PM   #3
KC95SC400
Trader Score: (0)
KC95SC400's Avatar
The prothane kits are kind of confusing. There is a "front" kit and a "rear" kit but I haven't seen where it says what's included. Does the front kit have upper and lower? Rear kit have upper and lower? Do they include sleeves?
I think the Supra kits that mvpmotorsports sells look like good quality. Just not 100% sure they will fit. They also appear to include the sleeves which I think would be easier to install and probably accounts for their higher cost.
Also if anyone knows, does anyone make solid driveshaft bushings / donuts? I could swear I've seen them but now I can't find them. Also thinking about solid diff mounts. Also thinking about changing the subframe mounts although I probably wouldn't use solid peices.
KC
__________________
Old 11-01-09, 01:57 AM   #4
Maeve
Trader Score: (0)
Maeve's Avatar
Quote:
Yes. It's for the front & rear - upper and lower with sleeves.
The rear has 14 bushings total.
Here is what's included in the kit.
Front kit:
Rear kit:
I got mine from Jegs for $161 shipped for both front & rear.
Here are the part numbers:
Front: 18-207-BL
Rear: 18-304-BL
__________________
SC400 Platinum
Maeve is offline   Reply With Quote
Old 10-31-09, 10:10 PM   #5
SC300_704
Trader Score: (0)
SC300_704's Avatar
i remember reading somewhere saying that the supra bushings fit but don't mark my words on that..i also need to change mines as well and maybe the mounts to, it's making a screeching sound every time i let off the clutch on take off.
__________________
93 SC300 5 speed (310+k miles)
NA-T coming soon!
SC300_704 is offline   Reply With Quote
Old 10-31-09, 11:55 PM   #6
v8soarer91
Trader Score: (0)
The only difference is that the soarer uses bushes that have "slits" which feel softer, and the supra uses solid bushes.
v8soarer91 is offline   Reply With Quote
Old 11-01-09, 01:36 AM   #7
Son Gokou
Trader Score: (0)
Send a message via ICQ to Son Gokou
You can get the BranZ bushes from here:
http://www.soarerparts.com/
They have soarer / sc 400 bushes in slotted or solid!
Son Gokou is offline   Reply With Quote
Old 11-01-09, 01:09 PM   #8
5sp_jzz30
Trader Score: (2)
5sp_jzz30's Avatar
^^^^^ 100% right
__________________
Old 11-01-09, 02:04 PM   #9
KC95SC400
Trader Score: (0)
KC95SC400's Avatar
Great post Maeve, helps allot.
So I guess they don't come with the outer sleeves, which was my main question about them. I suppose it's probably easier to burn out the rubber than press out the bushing with the outer sleeve anyway.
I assume all of you guys recommending them are happy with the Prothane kits then? No reason to spend twice as much if they are good.
KC
__________________
Old 11-01-09, 05:17 PM   #10
stevechumo
Trader Score: (0)
stevechumo's Avatar
Khris,
The Supra and SC lower control arms/bushings have the exact same dimensions. The only difference between the stock Supra LC bushing from the SC is its bushing is almost filled, while the SC has hole for more flexibility. I think the upper bushings aren't the same, so watch out on that.
You're looking at a messy job with a propane torch and a lot of burning and scraping/cleaning. You'll also need a t-clamp so it can push the stock rubber out while you burn it. I did it before. You'll need to keep the stock shell and maybe the center core if the kit doesn't have the center core. Don't grind the shell's inside too much because you'll thin it out and it'll need to fit snuggly over the new bushing.
If you only need to replace the LC bushings, David (Lextreme) has a lot of OEM SC LC bushings with complete unit. You'll only need to press out the old bushing with shell and press the new one in. That'll be much easier than burning/cleaning/greasing. I used the Daizen polyurethane bushings and its grease just keep being washed out by the rain and they cause squeaking all the time. I then went with the complete Supra LCAs.
__________________
C:\Documents and Settings\Thuy Chu\Desktop\SCEngine3.jpgSingle Turbo SC400 V8 on 13 psi, 334 rwhp and 378 rwtq (will boost more to confirm), Hi-Performance rebuilt tranny, Lextreme Hi-Performance Torque Converter, Tein SS, Supra LCA, LS and Supra Bigger Brakes, SS Brake Lines, Custom Body Kit.
stevechumo is offline   Reply With Quote
Old 11-01-09, 06:05 PM   #11
KC95SC400
Trader Score: (0)
KC95SC400's Avatar
Thanks for the info steve.
I actually got to thinking about it. I need the inner sleeves for the front lowers and the Prothane kits do not appear to have them.
I'm sure I need new bushings anyway but the main reason I want to replace them is because the lower, passenger side, rear camber/caster adjusting bolt is seized to the bushings inner sleeve. In the process of removing the arm I might be able to remove the bolt without damaging the sleeve but if I can't, I'm screwed if I don't have a replacement sleeve.
I have tried to remove the bolt before with the intention of replacing it (the bolt) with a new one. I heated it up as much as I felt comfortable doing without melting the bushing and hammered the heck out of it. It did not budge at all. There are other things I could try but its note a sure thing that the sleeve can be saved.
So, I need the inner sleeves for the lowers along with the bushings.
KC
__________________
Old 11-01-09, 10:54 PM   #12
stevechumo
Trader Score: (0)
stevechumo's Avatar
You're welcome, Khris. The OEM bushings that David has are the complete shell, rubber, and sleeve as the whole complete units. If you're not looking for firmer handling than stock, then I think using the OEM ones will avoid the headache and down time. It took me a whole day to burn and clean...etc.
__________________
Tags
93, arm, arms, bushing, bushings, common, control, drive, lexus, problems, replacement, sc, sc300, sc400, shaft, supra
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
