is this a good/legit camber kit ?
http://cgi.ebay.com/ebaymotors/SPC-R...ht_3998wt_1130
i thought they didnt even make camber kits for 2gs but anyways
are these legit? or will they just break down after a few months and cost me more money in the long run?
Master Thread Closer!!
The SPC camber kit requires you to self drill the camber bolt hole opening more longer...thus...you wont be able to go back to stock...unless you buy a new lower control arm.
they replace the stock camber bolt and offset washer setup. the larger washer gives you + or - 1 degree more adjustment. so if you decide to go back to stock springs and shocks, they will be fine, you will just have a camber bolt that is longer, and a bigger washer giving you more degrees of adjustment.
Former Sponsor
Hey guys,
Just wanted to post up a little info on SPC. They have specialized in the alignment industry for over 35 years and are the leaders in the camber kit industry. They also manufacture kits for Eibach, as well as, several automakers. Not to mention all items are covered by a lifetime warranty.
xspsi6
Suspension and Brakes
05-13-12 12:20 PM
