why do the rear brake pads of my GS always wear out twice as fast as the front pads?
Registered User
no, I do not drive it with the parking brake engaged... nor do I drive
backwards...
these are the regular Toyota pads from the dealer...
any guesses appreciated!
backwards...
i noticed too that when i clean my wheels, there always more brake dust on the rear wheels than the fronts. Probably cos the calipers are so small compared to the fronts and its a heavy car.
The reason why brake pads are smaller in the rear is because most of the car's weight is transferred to the front during the braking. Rear brake pads generally last (2 to 3 times) longer than the front pads. Maybe the calipers are seized.
Some brake pad compounds dust more than other types. For instance, stock OEM pads from BMW dust considerably more than stock OEM pads. Burma, you might have different brand pads in the fronts and rears.
Remove the caliper from the bracket and inspect the rubber boot around the piston to make sure that it's not torn. Then wedge a piece of wood or something in the middle of the twin piston and have someone step on the brakes so that the piston clamp down. Inspect the piston travel and the rubber boot fully extended. If everything looks good, then reassemble and you're good to go. If the piston are seized, then you will need to rebuild them.
I'm not too sure about this situation on Toyota/Lexus but I know on VW's the rear pads start 2mm less than the fronts. Also on VW's the rear caliper clamps first. Maybe something similar?
Any Lexus techs in here that could maybe shed a little light on why this is happening? I also had to replace the rear pads before the fronts on my GS
Japanland is marketed towards no noise, long pad life and little dust. the US market is moving toward the Japanese market trend.
are you SURE they're OEM pads? just because you bought and had pads installed from the dealer doesn't mean they necessarily put OEM pads on. did they ask you if you wanted OEM or less expensive aftermarket pads made for Toyota/Lexus?
Northern California Regional Officer
Actually the parking brake does not use the rear brake caliper pads, so that would not be it. There is another set of pads inside the drum that is dedicated for parking only.
I'll buy that, BUT do you use your left foot to brake and right foot for gas?
Forum Administrator
