Brake Pressure problem
Old 02-09-09, 07:09 PM
LexAudio83
LexAudio83's Avatar
Default Brake Pressure problem
I have this problem with my brakes that sometimes the pedal loses complete pressure and i have to let go and pump it once or twice to get pressure back. It started out with a spongy pedal and I have already flushed and bled my brake fluid 3 times. This last time the brakes were fine and then now the pedal loses pressure especially when traveling high speeds more often than not.
I am thinking maybe I need to change brake lines but before i go ahead and order maybe I can get some input on this.
Old 02-09-09, 07:18 PM
GSteg
GSteg's Avatar
If you're not leaking then it's not a brake line problem. Check for seized piston(s) just to eliminate the possibility of a bad caliper.
Sounds to me like the master cylinder is going out. I'm going to rebuild mine eventually just as a precaution so maybe you should too. Most of time when experiencing pressure loss, it's the master cylinder that should be looked at.
TriniLex
03-24-22 09:14 AM
R3VO666
03-19-19 05:56 PM
Jwild909
Suspension and Brakes
11-16-16 10:20 PM
gcam77
02-06-08 08:53 PM
Bane
06-13-05 01:06 PM
Quick Reply: Brake Pressure problem
